Issue with 5.0 beta 5 (MS4W 2.2.6)
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Aug 23 14:57:15 EDT 2007
John Cole wrote:
> Thanks Daniel,
>   The libmysql.dll fix worked.
John, can you confirm that you copied the libmysql.dll from MS4W 2.2.3
to fix the problem or did you get it from other source ? I will update
the ms4w downloads after that.
Thanks
> Daniel Morissette-2 wrote:
>> John Cole wrote:
>>> I'm using the freshly minted MS4W 2.2.6, which I believe has MS5 Beta 5
>>> and
>>> have the following issue.
>>> Maps returning are being drawn very quickly, but the browser (FF2 or IE7)
>>> are holding the connections open for 5+ seconds on each map request.
>>> This
>>> quickly adds up when tiling from MS.
>>> Looking at a mode=browse page, the following error is appearing when the
>>> connection is finally released:
>>> Error in my_thread_global_end(): 1 threads didn't exit
>> It seems that PHP 5.2.2 and 5.2.3 have a broken libmysql.dll, see:
>> http://bugzilla.maptools.org/show_bug.cgi?id=1730
>> ... and I also read elsewhere that using the libmysql.dll from MS4W
>> 2.2.3 could solve the issue.
>>> When debugging is on, I'm not getting any timing or layer stats anymore
>>> either.
>> This may be related to RFC-28 changes in 5.0. The short answer is that
>> with 5.0 you need to set in your mapfile:
>>    CONFIG MS_ERRORFILE "stderr"
>> ... and for the full story see
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-28
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
