Issue with 5.0 beta 5 (MS4W 2.2.6)
John Cole
john.cole at UAI.COM
Thu Aug 23 15:41:51 EDT 2007
I replaced it with the library from MS4W 2.2.2
John
Yewondwossen Assefa wrote:
> John Cole wrote:
>> Thanks Daniel,
>> The libmysql.dll fix worked.
> John, can you confirm that you copied the libmysql.dll from MS4W 2.2.3
> to fix the problem or did you get it from other source ? I will update
> the ms4w downloads after that.
> Thanks
>> Daniel Morissette-2 wrote:
>>> John Cole wrote:
>>>> I'm using the freshly minted MS4W 2.2.6, which I believe has MS5 Beta 5
>>>> and
>>>> have the following issue.
>>>> Maps returning are being drawn very quickly, but the browser (FF2 or
>>>> IE7)
>>>> are holding the connections open for 5+ seconds on each map request.
>>>> This
>>>> quickly adds up when tiling from MS.
>>>> Looking at a mode=browse page, the following error is appearing when
>>>> the
>>>> connection is finally released:
>>>> Error in my_thread_global_end(): 1 threads didn't exit
>>> It seems that PHP 5.2.2 and 5.2.3 have a broken libmysql.dll, see:
>>> http://bugzilla.maptools.org/show_bug.cgi?id=1730
>>> ... and I also read elsewhere that using the libmysql.dll from MS4W
>>> 2.2.3 could solve the issue.
>>>> When debugging is on, I'm not getting any timing or layer stats anymore
>>>> either.
>>> This may be related to RFC-28 changes in 5.0. The short answer is that
>>> with 5.0 you need to set in your mapfile:
>>> CONFIG MS_ERRORFILE "stderr"
>>> ... and for the full story see
>>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-28
>>> Daniel
>>> Daniel Morissette
>>> http://www.mapgears.com/
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
View this message in context: http://www.nabble.com/Issue-with-5.0-beta-5-%28MS4W-2.2.6%29-tf4317708.html#a12300477
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
