msautotest on Windows (buildbot) for MapServer 5.0
Frank Warmerdam
warmerdam at POBOX.COM
Tue Aug 28 18:17:56 EDT 2007
Tamas Szekeres wrote:
> 2007/8/28, Normand Savard <nsavard at mapgears.com>:
>> I noticed that the wxs/sld tests failed because the projection 42304 is
>> not found (see the error message below). The projection is defined in
>> the map file as:
>> PROJECTION
>> "init=./data/epsg2:42304"
>> END
>> The epsg2 file is really in the data directory. I have no idea right
>> now why it doesn't find the projection file on this Windows machine.
>> The Windows machine at our office didn't meet this issue.
> Normand,
> I think there's quite some confusion about how mapserv actually does
> the lookup of the epsg file for getting the project parameters.
> Therefore it's worth considering to embed the proj parameters in the
> mapfiles whenever it's possible so as to minimize the external
> dependencies of the tests.
> In this particular case I did some investigation and found that
> embedding that projection in c.\proj\nad\epsg could solve the issue on
> the windows builders.
Tamas,
Local lookups as done above *should* work. I'd rather track down
why they don't work in some circumstances. Do these never work on
windows, or are they just failing for some people?
>> Finally some of the tests failed because of floating point rounding
>> rules difference between Windows and Unix. These tests need to be
>> validated visually and move to the expected directory. They are:
> Perhaps we could alter the compare algorithm of the images using a per
> pixel method with a proper tolerance considering the difference
> between the rounding rules.
This is pretty tricky. But I'm hoping to review PerceptualDiff for
a fuzzier sort of image comparison. In the meantime we are stuck doing
visual comparisons.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
