msautotest on Windows (buildbot) for MapServer 5.0
Tamas Szekeres szekerest at GMAIL.COM
Tue Aug 28 19:01:06 EDT 2007
2007/8/29, Frank Warmerdam <warmerdam at pobox.com>:
> Local lookups as done above *should* work.  I'd rather track down
> why they don't work in some circumstances.  Do these never work on
> windows, or are they just failing for some people?
Hmmm... I don't know. According to the filemon output I'm pretty sure
in that when parsing the mapfile the pj_init is called with the
correct values.
But later somewhere between the map file parsing and the image saving
it might be overwritten by some other values and pj_init uses
eventually the default lookup path (PROJ_LIB apparently)
It's too late here to go further in the investigation for now, I'm not
familiar in wxs as much as not having to execute the code in the
debugger or so. Maybe tomorrow...
 0:21:30	mapserv.exe:5156	OPEN	C:\PROJ\NAD\proj_def.dat	SUCCESS	Options:
Open  Access: Read
Open  Access: 00100001
0:21:30	mapserv.exe:5156	QUERY
INFORMATION	C:\PROJ\NAD\proj_def.dat	SUCCESS	FileInternalInformation
0:21:30	mapserv.exe:5156	CLOSE	C:\PROJ\NAD\proj_def.dat	SUCCESS
0:21:30	mapserv.exe:5156	READ
	C:\PROJ\NAD\proj_def.dat	SUCCESS	Offset: 0 Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\proj_def.dat	SUCCESS	Offset:
0 Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\proj_def.dat	END OF
FILE	Offset: 278 Length: 4096
0:21:30	mapserv.exe:5156	OPEN	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\wms_sld.map	SUCCESS	Options:
Open  Access: Read
INFORMATION	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs	SUCCESS	FileNameInformation
INFORMATION	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\wms_sld.map	SUCCESS	FileInternalInformation
0:21:30	mapserv.exe:5156	CLOSE	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\wms_sld.map	SUCCESS
	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\wms_sld.map	SUCCESS	Offset:
0 Length: 8192
0:21:30	mapserv.exe:5156	READ	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\wms_sld.map	SUCCESS	Offset:
8192 Length: 4096
12288 Length: 4096
16384 Length: 4096
20480 Length: 4096
24576 Length: 4096
0:21:30	mapserv.exe:5156	OPEN	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\data\epsg2	SUCCESS	Options:
Open  Access: Read
INFORMATION	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\data\epsg2	SUCCESS	FileInternalInformation
0:21:30	mapserv.exe:5156	CLOSE	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\data\epsg2	SUCCESS
	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\data\epsg2	SUCCESS	Offset:
0 Length: 4096
0:21:30	mapserv.exe:5156	READ	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\wms_sld.map	END
OF FILE	Offset: 25861 Length: 4096
Open  Access: Read
0 Length: 4096
Open  Access: Read
0 Length: 4096
Open  Access: Read
0 Length: 4096
0:21:30	mapserv.exe:5156	OPEN	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\mapserver\gdalplugins\	NOT
FOUND	Options: Open Directory  Access: 00100001
0:21:30	mapserv.exe:5156	OPEN	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\symbols.sym	SUCCESS	Options:
Open  Access: Read
INFORMATION	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\symbols.sym	SUCCESS	FileInternalInformation
0:21:30	mapserv.exe:5156	CLOSE	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\symbols.sym	SUCCESS
	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\symbols.sym	SUCCESS	Offset:
0 Length: 8192
0:21:30	mapserv.exe:5156	READ	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\symbols.sym	END
OF FILE	Offset: 1225 Length: 4096
OF FILE	Offset: 1225 Length: 8192
0:21:30	mapserv.exe:5156	OPEN	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\fonts.txt	SUCCESS	Options:
Open  Access: Read
INFORMATION	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\fonts.txt	SUCCESS	FileInternalInformation
0:21:30	mapserv.exe:5156	CLOSE	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\fonts.txt	SUCCESS
	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\fonts.txt	SUCCESS	Offset:
0 Length: 4096
0:21:30	mapserv.exe:5156	READ	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\etc\fonts.txt	END
OF FILE	Offset: 52 Length: 4096
0:21:30	mapserv.exe:5156	OPEN	C:\PROJ\NAD\epsg	SUCCESS	Options: Open
Access: Read
Access: 00100001
INFORMATION	C:\PROJ\NAD\epsg	SUCCESS	FileInternalInformation
0:21:30	mapserv.exe:5156	CLOSE	C:\PROJ\NAD\epsg	SUCCESS
0:21:30	mapserv.exe:5156	READ 	C:\PROJ\NAD\epsg	SUCCESS	Offset: 0 Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 4096
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 8192
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 12288
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 16384
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 20480
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 24576
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 28672
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 32768
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 36864
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 40960
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 45056
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 49152
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 53248
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 57344
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 61440
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 65536
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 69632
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 73728
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 77824
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 81920
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 86016
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 90112
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 94208
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 98304
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 102400
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 106496
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 110592
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 114688
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 118784
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 122880 Length: 1
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 126976
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 131072
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 135168
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 139264
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 143360
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 147456
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 151552
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 155648
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 159744
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 163840
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 167936
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 172032
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 176128
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 180224
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 184320
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 188416
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 192512
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 196608
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 200704
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 204800
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 208896
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 212992
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 217088
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 221184
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 225280
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 229376
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 233472
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 237568
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 241664
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 245760
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 249856
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 253952 Length: 1
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 258048
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 262144
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 266240
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 270336
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 274432
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 278528
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 282624
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 286720
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 290816
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 294912
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 299008
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 303104
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 307200
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 311296
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 315392
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 319488
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 323584
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 327680 Length: 1
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 331776
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 335872
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 339968
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 344064
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 348160
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 352256
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 356352
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 360448
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 364544
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 368640
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 372736
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 376832
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 380928
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 385024
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 389120
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 393216
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 397312
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 401408
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 405504
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 409600
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 413696
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 417792
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 421888
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 425984
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 430080
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 434176
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 438272
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 442368
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 446464
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 450560
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	SUCCESS	Offset: 454656
Length: 4096
0:21:30	mapserv.exe:5156	READ	C:\PROJ\NAD\epsg	END OF FILE	Offset:
455959 Length: 4096
455959 Length: 4096
0:21:30	mapserv.exe:5156	WRITE
	E:\buildbot\osgeo\slaves\szekerest-msvc80-mapserver\szekerest-vc80-quick\build\msautotest\wxs\result\wms_get_map_line_sld.png	SUCCESS	Offset:
0 Length: 406
Best regards,
Tamas
