Still having problems w/ definition of symbol 0
Julia Harrell
julia.harrell at NCMAIL.NET
Wed Aug 29 13:19:30 EDT 2007
Hi Daniel
I think we are also experiencing this particular issue, but since we're MS4W
users,
we don't have the ability to compile and use the latest source code. We did
upgrade
to the MS4W 2.2.6 beta this morning, which uses MapServer 5.0-beta5. We were
hoping
that your fix for this issue and the long-awaited deprecation of all the
various
hard-coded limits in ms-rfc-17 would be included this version and fix our
problems,
but this "Undefined overlay symbol" error is still creating some havoc for
us.
The error message is:
ERROR msLoadMap(): General error message. Undefined overlay symbol
'dashed5'
in class 3, style 0 of layer Geologic_Structures. msAddImageSymbol():
Unable to access file. Error opening image file
C:\ms4w\Apache\cgi-bin/.\dashed5.
Problem symbol definitions in our symbol file start at:
# Symbol Index 17
SYMBOL
NAME 'dashes'
TYPE TRUETYPE
FONT "Bookshelf Symbol 7"
CHARACTER "u"
ANTIALIAS TRUE
GAP 24
END
END
# Symbol Index 18
SYMBOL
NAME 'dashed5'
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
STYLE 0 12 4 16
END
END
The layer definition in our map file where we experience the problem:
LAYER
NAME 'Geologic_Structures'
GROUP 'Geology and Hydrogeology'
DATA 'C:\gisdata\geol250s_arc.shp'
PROJECTION
"init=epsg:32119"
END #end projection
TYPE line
STATUS DEFAULT
TOLERANCE 8 #default is 3 for raster, 0 for vector
CLASS
NAME '1 - fault'
EXPRESSION ('[TYPE]' eq '1')
STYLE
SYMBOL 'dashed2'
COLOR 204 204 204
SIZE 3
END #end style
STYLE
SYMBOL 'dashed2'
COLOR 051 051 051
SIZE 2.5
END #end style
END # end class
CLASS
NAME '2 - fold'
EXPRESSION ('[TYPE]' eq '2')
STYLE
SYMBOL 'dashed3'
COLOR 051 051 051
SIZE 2.5
END #end style
STYLE
SYMBOL 'dashed4'
COLOR 051 051 051
SIZE 8
END #end style
END # end class
CLASS
NAME '3 - scarp'
EXPRESSION ('[TYPE]' eq '3')
STYLE
SYMBOL "circle"
COLOR 051 051 051
SIZE 2.5
END #end style
END # end class
CLASS # this all works, but not when using dashed5
NAME '4 - geologic contact'
EXPRESSION ('[TYPE]' eq '4')
#STYLE
SYMBOL 'dashed5' ### tried SYMBOL 18 here too
COLOR 051 051 051
SIZE 2.5
#END #end style
END # end class
CLASS # 28
NAME '5 - structural symbol'
EXPRESSION ('[TYPE]' eq '5')
STYLE
SYMBOL 'dashed3'
COLOR 051 051 051
SIZE 2.5
END #end style
END # end class
END #end layer geologic structures
In our mapfile, we have:
47 layers in total
111 classes in total, with a max of 21 in any given layer
The layer we have issues with has only 5 classes
112 styles in total, with a max of 21 in any given layer
The layer we have issues with has distinct 7 styles in the 5
classes,
with the problem symbol being the sole symbol in its style & class
In our symbol file, we have 25 symbols, but we are currently only using 12
of them in
the map file. Symbol 18 ("dashed5") is giving us this particular error.
Symbols 1 - 16 all
work, but symbols at index 17 or higher give us this same error if
referenced by name in
the map file. If the symbold is referenced by index number, we don't get the
error and
the map renders, but that particular symbol does not.
For the life of us, we can't see what's different with this symbol than most
of the
others. Is there anything we can do to get around this problem, using
pre-compiled
MS4W binaries? It's a real showstopper for us, because we have a lot of data
layers
we really need to include in our groundwater quality decision support
viewer.
Best Regards,
Julia Harrell
GIS Coordinator, NC DENR
julia.harrell at ncmail.net
>>>The issue was happening only when accessing the first symbol in your
>>>symbolset by name.
>>>I had accidentally screwed up the definition of symbol 0 (the default
>>>symbol) in msInitSymbolSet(). This is fixed in r6339.
>>>Daniel
View this message in context: http://www.nabble.com/SVN-Broken-tf4103508.html#a12391657
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
