CSharp MapScript doesn't like AGG
Daniel Morissette
dmorissette at MAPGEARS.COM
Thu Aug 30 08:55:51 EDT 2007
Mike Leahy wrote:
> I do realize this - I just like to try new things when I can. I'm under the
> impression that if I notice a problem, then it's worthwhile to mention it
> (if that's not the case, then please let me know).
Yes, anything that doesn't work is worth mentioning (whether all issues
are worth fixing is a different question). I didn't mean to stop you
from trying new combinations, I just noticed that lots of users seem to
get into trouble by trying to include all possible options and wanted to
make sure you realized the danger with that.
> At any rate, this doesn't apply to the AGG case - I really would like that
> to work, as the improvement in the graphical output is quite noticeable. I
> only mentioned the other options because the pattern I noticed is similar -
> everything compiles fine, mapserver works, PHP MapScript works, but the
> CSharp module fails when used at runtime.
Correct, and hopefully it's something simple to track and fix once
someone opens it up in a debugger.
Dnaiel
Daniel Morissette
http://www.mapgears.com/
