Lines with truetype font symbols
thomas bonfort
thomas.bonfort at GMAIL.COM
Thu Aug 30 09:31:26 EDT 2007
yes it's a bug. thanks for the report, I'll fix asap.
tb
On 8/30/07, Håvard Tveite <havard.tveite at umb.no> wrote:
> I am using short straight lines of truetype font symbols to
> place oriented symbols on the map at specific locations.
> In Mapserver 4.10 this worked OK, but in 5.0b5 it gives the
> expected results for lines going from west to east (larger
> x-coordinate for the end than the start of the line), but
> the opposite orientation of the symbol for lines that go
> from east to west (larger x-coordinate for the start than
> the end of the line).
> Is this expected behaviour?
> A map file that illustrates the problem:
> MAP
> SIZE 100 100
> EXTENT 0 0 100 100
> PROJECTION
> "init=epsg:32633"
> END
> FONTSET /usr/openwin/lib/X11/fonts/TrueType/font.list
> WEB
> IMAGEPATH "/users/ikf/ikfht/public_html/mapserver/tmp/"
> IMAGEURL "/~ikfht/mapserver/tmp/"
> TEMPLATE test.html
> END #web
> SYMBOL
> NAME "tttriangle"
> TYPE truetype
> FONT arial
> GAP -1 # change in mapserver 5!
> CHARACTER ">"
> END
> LAYER
> NAME "orientation"
> TYPE LINE
> STATUS DEFAULT
> FEATURE
> # line from west to east
> POINTS
> 50 10
> 85 50
> END # Points
> TEXT 'OK'
> END # Feature
> FEATURE
> # line from east to west
> POINTS
> 50 60
> 10 90
> END # Points
> TEXT '!OK'
> END # Feature
> CLASS
> NAME "symbolline"
> STYLE
> COLOR 255 0 255 # magenta
> SYMBOL 'tttriangle'
> SIZE 20
> END #style
> LABEL
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> END # label
> END #class
> END #layer orientation
> END # Map file
> Mapserver 5.0b5:
> http://gis.umb.no/cgi-bin/mapserv_5?map=/users/ikf/ikfht/mapserv/tests/orientation.map
> Mapserver 4.10.0:
> http://gis.umb.no/cgi-bin/mapserv_4?map=/users/ikf/ikfht/mapserv/tests/orientation.map
> MapServer version 5.0.0-beta5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=SDE INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
