agg changes
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Aug 30 09:58:48 EDT 2007
Paul,
Unfortunately at a few days from the release I think it's too late to
strip out stuff. Your reasoning makes sense, but in the interest of
getting a release out I have to say "no more changes in 5.0".
Daniel
Paul Spencer wrote:
> Steve,
> I'd like to suggest defering cartographic enhancements (by which I mean
> additional keywords in the map file to specify more advanced
> cartographic options) until post 5.0.  I think, since you are moving
> from 4.x to 5.x and *can* make some changes that are not necessarily
> backwards compatible, that you should consider removing things from the
> mapfile at this point that don't work or won't be supported in order to
> establish a minimum baseline which the 5.x series can build on by adding
> new features without having to make an incompatible change in the next
> version.  Essentially, I am advocating stripping out as much as
> possible/practical, and then adding new stuff post 5.0.
> Looking forward to 5.2, I think it would be really beneficial to start a
> dialog with the user community on cartographic needs and try to
> establish a set of requirements that can be built towards in the 5.x
> series.  I know that MapGuide has implemented point and line support for
> a massive USGS cartographic standard and has some very impressive demos
> of the new cartography.  There is also a large document describing the
> cartographic needs of the Canadian national dataset folks.  There are
> probably other 'standards' out there too.
> AGG has given mapserver an excellent foundation to build on for premium
> cartography, and I think it would be a mistake to leave stuff in
> mapserver 5.0 that we may regret post 5.0.
> Cheers
> Paul
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
Daniel Morissette
http://www.mapgears.com/
