CSharp MapScript doesn't like AGG
Tamas Szekeres
szekerest at GMAIL.COM
Thu Aug 30 16:49:12 EDT 2007
Mike,
I've just committed the fix in the trunk (r6753)
Would you mind making a test with the latest version?
Best regards,
Tamas
2007/8/30, Mike Leahy <mgleahy at golden.net>:
> On Thu, 30 Aug 2007 08:22:02 -0400, Daniel Morissette
> <dmorissette at MAPGEARS.COM> wrote:
> >I can't help with CSharp, but stuff like --enable-coverage is of no use
> >to anyone unless you want to do profiling so why would you want to
> >include that option in your build? Hopefully you realize that by
> >including options that you don't need in your build you are bloating it
> >and will end up with a binary that may be less optimal than what you'd
> >get if you picked only the options that you need.
> >Daniel
> I do realize this - I just like to try new things when I can. I'm under the
> impression that if I notice a problem, then it's worthwhile to mention it
> (if that's not the case, then please let me know).
> At any rate, this doesn't apply to the AGG case - I really would like that
> to work, as the improvement in the graphical output is quite noticeable. I
> only mentioned the other options because the pattern I noticed is similar -
> everything compiles fine, mapserver works, PHP MapScript works, but the
> CSharp module fails when used at runtime.
> Mike
