svn build error...
Frank Warmerdam
warmerdam at POBOX.COM
Wed Dec 19 12:48:42 EST 2007
Steve Lime wrote:
> Antique is right (v 1.2.6). This is back from when you helped me compile the early releases of the ECW
> code from ERMapper. I was always scared to touch it after that. Time to upgrade I think but I'll wait
> to test your checks.
Steve,
I have committed some changes that should use older stuff for older versions of
GDAL. Could you test build again. If it is not inconvenient for you, I'd
be pleased for you to keep using 1.2.6 if only to confirm that mapserver
continues to work smoothly with it.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
