svn build error...
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Dec 19 13:11:33 EST 2007
Now getting:
g++ -c -O2 -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCAT -DUSE_WMS_LYR -DUSE_LIBXML2 -DUSE_CURL -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_ORACLESPATIAL -DUSE_POSTGIS -DUSE_GDAL -DUSE_OGR -DUSE_GEOS -DUSE_SDE -DUSE_PROJ -DUSE_EPPL -DUSE_AGG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB -I/usr/include -I/usr/local/src/agg-2.4/include -I/usr/local/src/agg-2.4/font_freetype -I/usr/include/freetype2 -I/usr/local/include -I/usr/local/esri/sdeexe91/include -I/usr/local/include -I/usr/local/pgsql/include -I/usr/include/oracle/10.2.0.1/client -I/usr/rdbms/demo -I/usr/rdbms/public -I/usr/local/include -I/usr/include/libxml2 mapogr.cpp -o mapogr.o
/usr/local/include/ogr_api.h: In function `int msOGRFileWhichShapes(layerObj*,
rectObj, msOGRFileInfo*)':
/usr/local/include/ogr_api.h:214: error: too few arguments to function `void
OGR_G_AddPoint(void*, double, double, double)'
mapogr.cpp:1087: error: at this point in file
mapogr.cpp:1088: error: at this point in file
mapogr.cpp:1089: error: at this point in file
mapogr.cpp:1090: error: at this point in file
mapogr.cpp:1091: error: at this point in file
make: *** [mapogr.o] Error 1
Steve
>>> On 12/19/2007 at 11:48 AM, in message <4769597A.90903 at pobox.com>, Frank
Warmerdam <warmerdam at pobox.com> wrote:
> Steve Lime wrote:
>> Antique is right (v 1.2.6). This is back from when you helped me compile the
> early releases of the ECW
>> code from ERMapper. I was always scared to touch it after that. Time to
> upgrade I think but I'll wait
>> to test your checks.
> Steve,
> I have committed some changes that should use older stuff for older versions
> of
> GDAL. Could you test build again. If it is not inconvenient for you, I'd
> be pleased for you to keep using 1.2.6 if only to confirm that mapserver
> continues to work smoothly with it.
> Best regards,
