Performance transparency
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Dec 19 13:31:16 EST 2007
Hi Johan: I've never quantified the performance hit but it is certainly expected. Layer-level transparency works like this:
- a temporary image is created to render the transparent layer into, it is initialized to be completely transparent
- rendering proceeds as normal in the temp image
- the temp image is then "merged" into the base image, so for every non-transparent pixel in the temp image alpha blending is done and the base image pixel is modified
- the temporary image is discarded
So, the processing time will increase with 1) image size and 2) vector layer density.
There are plans to support feature-level transparency but it won't work in all cases so layer level transparency will remain an option.
So, the results you are seeing are expected although I can't say if double is too much or not.
Steve
>>> On 12/19/2007 at 8:49 AM, in message
<D93CFEAA72FA764885CC1FDA94A1D89C035462F2 at WMRI000166.corp.wmdata.net>, Hallgren
Johan E <jhhal at WMDATA.COM> wrote:
> Hello Friends
> I a question regarding performance when using a transparent vectorlayer
> on top of a rasterlayer. The output is quite large (1400 * 1000 px) and
> vectordata is a shapefile with polygons.
> When turning the transparency on the vector layer the performance goes
> down quite much. It takes maybe double as long time to produce the map.
> Is there any knowledge about that?
> /Johan
> ___________________________________
> Johan Hallgren
> WM-data, Logica CMG
> Pelle Bergs backe 3
> Box 1938, 791 19 Falun
> Tel (och mobil): 023-547 46 (int: +46-2354746)
> johan.e.hallgren at wmdata.com
> <blocked::mailto:johan.e.hallgren at wmdata.com>
> http://www.wmdata.se
> <blocked::https://webaccess.wmdata.com/exchweb/bin/redir.asp?URL=http://
> www.wmdata.se/>
