saved_extent parameter in the map
Yewondwossen Assefa yassefa at DMSOLUTIONS.CA
Wed Dec 19 16:34:14 EST 2007
Hi There,
  The saved_extent parameter in the map object seem to be used for
internal calculation. I have seen it recently used with Mapscript swig
generated bindings (It is not exposed in php mapscript). Should it be
removed from the swig mapscript?
  Note that in the case I have seen, the saved_extent was used in
scripts as a mechanism to extract the original map extent set in the map
file, which I think is not the intended behavior. I think this could be
accomplish either at the application level or even using the web->extent
parameter.
Thanks
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
