saved_extent parameter in the map
Tamas Szekeres
szekerest at GMAIL.COM
Wed Dec 19 17:47:56 EST 2007
Assefa,
I consider it's exposed inadvertently and can safely be removed from
the SWIG interface.
Best regards,
Tamas
2007/12/19, Yewondwossen Assefa <yassefa at dmsolutions.ca>:
> Hi There,
> The saved_extent parameter in the map object seem to be used for
> internal calculation. I have seen it recently used with Mapscript swig
> generated bindings (It is not exposed in php mapscript). Should it be
> removed from the swig mapscript?
> Note that in the case I have seen, the saved_extent was used in
> scripts as a mechanism to extract the original map extent set in the map
> file, which I think is not the intended behavior. I think this could be
> accomplish either at the application level or even using the web->extent
> parameter.
> Thanks
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
