bug in GML writer
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Fri Feb 2 17:52:04 EST 2007
Sorry guys, false alarm.
Appears the EXTENT in the MAP file had a MAXY value which was a little bit
too small.
Is there any way to change the current behaviour in Mapserver so that a
GetFeature request without a spatial filter won't use the MAP's EXTENT?
I've run into this too many times ..... :-(
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
Onderwerp: bug in GML writer
Datum: 02/02/07 21:46
> Hi list,
> I am using a simple shapefile (provinces of Holland), but what Mapserver
WFS
> produces misses a few of the features present in the shapefile. I have
> tested this both in ArcMap and TatukGIS as well as using OGR or Mapserver
> native shapefile driver, so it must be a bug in the GML writer. Both GML2
> and GML3 suffer from this.
> This seems like a pretty critical bug to me.
> A screendump from the situation can be seen here:
> http://www.osgis.nl/download/mapserver/mapserver_wfs_bug.png
> The MAP file plus shapefile can be downloaded from:
> I've opened up the following bug for reference:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2022
> Best regards,
> Bart
> http://www.osgis.nl
