exporting layers to OGC interfaces
Frank Warmerdam
warmerdam at POBOX.COM
Wed Feb 21 21:48:06 EST 2007
Paul Ramsey wrote:
> But it is what we are used to. Changing behavior is worse. I mean, I
> don't write a WMS map file and then not test it to see what capabilities
> it is advertising. So the fact that it is advertising all my layers is
> hardly a surprise. On the other hand, "upgrading" my mapserver and
> finding that all my layers mysteriously "disappear" from my service --
> *that* would be a surprise.
> P
> Daniel Morissette wrote:
>> Paul Ramsey wrote:
>>> In order to retain current behavior, the absence of the keyword
>>> should be equivalent to "all", and there should be a "none".
>> I really meant to suggest that we break compatibility because the
>> current behavior is opening up everyone's data by default, which I
>> find bad.
Folks,
I think I see Daniel's point, but I am not at all that an "information
protection" default is worth the disruption of changing the default
behavior. So, I'm not in favor of changing the default unless a more
compelling case can be made for it.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
