Add shapeObj.DouglasPeuckerSimplifier() in MapScript?
Paul Ramsey
pramsey at REFRACTIONS.NET
Fri Feb 23 19:12:53 EST 2007
Note that GEOS also has simplifying functions in it. A naive one, and a
"topology preserving" one that tries not to wreck polygons in the process.
Steve Lime wrote:
> The API (that I knew about) is already exposed via mapscript. That
> generalization function
> is new to me. Easy enough to add to mapgeos.c and then mapscript.
> Exposing it as a layer processing option is another matter and is a
> good fit for
> Tamas data adapter RFC. Note that I translated the Peucker algorithm
> from ESRI Avenue
> to MapScript (in perl) years ago (see
> http://mapserver.gis.umn.edu/community/scripts).
> Steve
>>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 2/23/2007 4:35:01 PM
> Daniel Morissette wrote:
>> We have a need to simplify (generalize) some shapefiles and we'll
>> probably do that by hacking a local copy of MapScript to add a
>> shapeObj.DouglasPeuckerSimplifier() that calls GEOS'
>> DouglasPeuckerSimplifier() function.
>> Should we consider integrating this new method in MapServer for 5.0?
> I
>> realize that generalizing data is a bit off-topic for MapServer, I'm
>> sending this to find out whether others think this belongs in
> MapServer
>> or not.
>> Daniel
> I think that exposing GEOS api via mapscript makes sense. A big part of
> working with mapserver is being able to prep the data that you will
> ultimately serve. I think mapscript is a great way to do this. People
> that are already working with mapserver/mapscript could use it to do a
> variety of tasks in this area without having to download and learn
> other
> tools. I do not think exposing these apis in mapscript should impose a
> lot of additional baggage on mapserver other than documenting them.
> The other option might be to look at adding it to ogr or looking at a
> separate project to focused on building an opensource variant of
> something like fme, which is probably outside the scope of your
> immediate needs, but might be an interesting project none the less.
> -Steve W
Paul Ramsey
Refractions Research
http://www.refractions.net
pramsey at refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
