Label Cache Performance
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jan 2 11:00:31 EST 2007
Interesting idea. No, it's not been looked at before, not by me anyway.
Frank might have some
thoughts on performance. You'd still have to loop through the affected
area to find collisions but
I think your correct in that the search time would basically be
constant (affected slightly by the
size of the label).
Wouldn't be that hard to implement. I wonder if GD holding the cache
image could be useful or
if a custom 2-D bit array would be faster- probably the latter...
Steve
>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 1/2/2007 9:46:46 AM
HNY All,
Last year I spent a fair amount of time optimizing a bunch of mapfiles
for performance. One of the areas that seems to always be a performance
hog if processing the Label Cache. I have been successful are thinning
down the number of labels going into the cache, but I wondering if
there
might be a more efficient way of dealing with it. Since I have been
playing with rasters over the holidays I was wondering if it might be
possible to implement the label cache as a bitmap mask and us a raster
OP to see if there is a collision?
OK, I'm sure it is possible, I guess my real question(s) are:
Has this approach been looked at before?
Any thoughts on performance?
My idea is:
1) create an label cache image
2) to check a label,
get its bbox polyon
check if it overlaps and set pixels
3) polygon fill the bbox of a label into the label cache image
when a label is rendered
we might be able to use a 2:1 or 4:1 reduced size label cache image
with
some thought about how to work around the issues.
I would think that this would be much faster than searching a list of
drawn labels and checking for intersections. And it should be linear
with the number of labels in the cache.
-Steve
