KML output format?
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Jan 4 13:50:58 EST 2007
Steve Lime wrote:
> I was thinking of something like this in a more general sense, that is
> being able to
> return a set of features from a query (even selection by bbox is really
> just a form
> of a query) through an OGR driver. That way you could support creating
> KML, Shapefiles
> or whatever OGR supports via MapScript, the CGI, WMS or WFS.
> I don't think concentrating on just WMS, or just KML makes good sense.
I thought about an OGR driver too, that would be very useful in several
situations but I had come back to the direct KML output format option
since that seemed simpler to implement.
Unfortunately for the KML case using OGR to generate the output would
not allow us to easily apply styles (colors, symbols) to the shapes. We
would probably need to generate OGR style strings in MapServer to pass
to the driver and extend the OGR-KML driver to support style strings (I
assume it doesn't at the moment). There is also the overhead of having
OGR write the output to disk and then having MapServer read and return
the contents of the output. Also what to do with formats that generate
multiple files (e.g. shapefiles, TAB datasets, etc.)? Should MapServer
zip them up before returning them? And if yes how does MapServer know
exactly which files to include in the ZIP for each OGR output format?
Actually, how is this handled at the moment with GDAL output formats?
An OGR output driver is definitely feasible and means more reusability,
but that's also more involved than a direct KML output format
implementation, that's why that was not my preferred option initially.
Daniel
Daniel Morissette
http://www.mapgears.com/
