Status of AGG support?
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Wed Jul 4 08:06:46 EDT 2007
Stephen Woodbridge wrote:
> Paul, Steve, et al,
> I have mapserver trunk built with AGG but have little clue on how to use
> it at this point. Googling shows up two trac tickets #2114 and #2115
> which show:
> OUTPUTFORMAT
>     NAME "agg/png24"
>     MIMETYPE "image/png; mode=24bit"
>     DRIVER "AGG/PNG"
>     EXTENSION "png"
>     IMAGEMODE "RGB"
>     FORMATOPTION "PALETTE_FORCE=TRUE"
>     FORMATOPTION "PALETTE=/my/path/palette.txt"
> END
> So this looks like the deal. What is palette.txt and does one define
> that. I assume this controls the problem with tiles shifting colors
> because the color palette overflows based on the anti-aliasing using up
> the color slots. Is this then a list of the primary colors that you want
> pre-allocated in you image so they do not shift.
  Yes that is correct. The colors in the palette will always be
allocated when converting from 24bit to 8 bits.
> What is the format of the file?
  The file syntax is R,G,B values on each line:
  242,236,230
150,150,150
Later,
> Thanks,
>   -Steve
> Paul Spencer wrote:
>> The other thing that I am very keen to have is text rendered/placed
>> using AGG.  Not sure if it will be done for 5.0 though.
>> Cheers
>> Paul
>> On 3-Jul-07, at 1:25 PM, Steve Lime wrote:
>>> Hi Tom: AGG support is in the codebase for 5.0. I still owe an RFC to
>>> explain what was
>>> done although the addition of AGG doesn't affect any other portions
>>> of MapServer. It's
>>> a big user feature though. I recently got a big time sink off my
>>> plate and will work that up
>>> ASAP.
>>> The support is relatively complete. The guys from DM Solutions can
>>> probably comment
>>> further as they've been using it the most. The AGG vs. GD images DM
>>> has supplied are
>>> very nice. The quality difference is noticeable with roads in
>>> particular.
>>> The only missing capability that I am aware of has to do with PIXMAP
>>> symbols that contain
>>> an alpha channel. There is a fundamental difference in how AGG and GD
>>> handle alpha
>>> blending (GD is flat out backwards).  We use GD to manage the pixel
>>> buffer that AGG is
>>> rendering into so that becomes a problem. I'll go into options in the
>>> RFC.
>>> Anyway, other than that the support seems to be working nicely is
>>> worth trying.
>>> Steve
>>>>>> On 7/1/2007 at 10:08 PM, in message
>>> <7b5b710d0707012008i59c41e8bq8e0ef4d8022f40f8 at mail.gmail.com>, Tom Beard
>>> <tom at PROJECTX.CO.NZ> wrote:
>>>> Hi there,
>>>> This is my first time posting here, and I hope this is the right
>>>> forum to
>>>> ask this question.
>>>> I was wondering what the status of AGG support was for the 5.0
>>>> release. On
>>>> searching the archives, the most recent reference I could find was the
>>>> minutes from the May 22 IRC meeting that said that there would be an
>>>> RFC
>>>> freeze on June 15, and that an RFC for AGG was "forthcoming". Did AGG
>>>> support make it into that freeze? Is it listed somewhere online?
>>>> I'd also be interested to know if there is a version currently in
>>>> Subversion
>>>> that includes AGG sub-pixel rendering and that works well enough to
>>>> have a
>>>> go at compiling on Windows.
>>>> Regards,
>>>>             Tom Beard
>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>> |Chief Technology Officer                                         |
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
