RFC-24 macros question
Daniel Morissette dmorissette at MAPGEARS.COM
Mon Jul 9 16:03:56 EDT 2007
Umberto,
As part of your work on RFC-24 you defined the following two macros:
#define MS_REFCNT_IS_NOT_ZERO(obj) (MS_REFCNT_DECR(obj))>0
#define MS_REFCNT_IS_ZERO(obj) (MS_REFCNT_DECR(obj))<=0
I find the name of the macros confusing when we encounter them in if
statements in the code because it is not obvious that they include an
implicit decrement of the refcount. At first I thought the code calling
them was just testing whether refcount was zero but I didn't realize
until I looked at the macros that they also decremented it.
Would it not be better if the macros were named in a way that made it
clear that they will also decrement refcount, perhaps:
#define MS_REFCNT_DECR_NOT_ZERO(obj) (MS_REFCNT_DECR(obj))>0
#define MS_REFCNT_DECR_ZERO(obj) (MS_REFCNT_DECR(obj))<=0
What do you think?
Daniel
Daniel Morissette
http://www.mapgears.com/
