Call for vote on MS-RFC-17: Dynamic allocation of symbols,
layers, etc.
Tamas Szekeres
szekerest at GMAIL.COM
Mon Jul 16 17:20:41 EDT 2007
+1
The mappluginlayer stuff should be concretized a bit. That static
repository of the vtables would prevent from loading the same library
twice. That array should also be allocated dynamically since I don't
think we will ever have MS_MAXLAYERS number of different plugin
layers.
Best regards,
Tamas
2007/7/13, Daniel Morissette <dmorissette at mapgears.com>:
> I would like to call for a vote to adopt MS-RFC-17 Dynamic Allocation of
> layers, styles, classes and symbols for implementation in MapServer 5.0:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-17
> I open the vote with my +1.
> Note: Based on feedback from Frank and Umberto, it doesn't seem that the
> potential backwards compatibility issue related to bypassing the
> insert/add methods in SWIG MapScript is still current, so I have moved
> this item out of the "backwards compatibility section" of RFC-17.
> However I kept it for reference in the "Questions from the review
> period" at the end of the RFC.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
