mapagg.cpp fixes, and outstanding issues
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Jul 17 03:08:52 EDT 2007
I thought I had enabled agg support and I find out only now that
mapserver configure script fails to detect my agg installation unless
I use this option:
--with-agg=/usr
Is this the expected behaviour?
I am on ubuntu feisty (32 bit).
Umberto
On 7/17/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Folks,
> I updated mapagg.cpp to build. I think Umberto changed the symbolset but
> this wasn't accounted for in mapagg.cpp.
> I also removed some unused variables, and fixed C++ initializer order
> related warnings.
> But there are still several warnings left:
> mapagg.cpp: In function `void msDrawMarkerSymbolAGGEllipse(symbolObj*, double,
> double, double, char, styleObj*, int, int, int, int, gdImage*, pointObj*)':
> mapagg.cpp:535: warning: passing `double' for converting 7 of `void
> gdImageFilledArc(gdImage*, int, int, int, int, int, int, int, int)'
> mapagg.cpp:536: warning: passing `double' for converting 7 of `void
> mapagg.cpp:540: warning: passing `double' for converting 7 of `void
> mapagg.cpp: In function `void msDrawMarkerSymbolAGGVector(symbolObj*, double,
> double, double, char, styleObj*, int, int, int, int, gdImage*, pointObj*,
> imageObj*)':
> mapagg.cpp:557: warning: 'width' might be used uninitialized in this function
> mapagg.cpp: In function `void msDrawMarkerSymbolAGG(symbolSetObj*, imageObj*,
> pointObj*, styleObj*, double)':
> mapagg.cpp:687: warning: 'offset_x' might be used uninitialized in this function
> mapagg.cpp:687: warning: 'offset_y' might be used uninitialized in this function
> mapagg.cpp:689: warning: 'd' might be used uninitialized in this function
> mapagg.cpp: At global scope:
> mapagg.cpp:331: warning: 'void imageFilledPolygon2(imageObj*, shapeObj*,
> colorObj*, int, int)' defined but not used
> mapagg.cpp:904: warning: 'nmsTransformShapeAGG' defined but not used
> Several of these seem fairly serious. For instance width, offset_x and
> offset_y seem to be used variables but never set anywhere!
> I'd appreciate the module authors reviewing them carefully and
> addressing them so we have a fairly clean build.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
