mapagg.cpp fixes, and outstanding issues
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jul 17 17:18:17 EDT 2007
Yes this is expected, configure.in doesn't make any assumption about where AGG might
be installed. I see that the GD section does a check in /usr and /usr/local. I can try and
implement that (but after the 23rd).
Steve
>>> On 7/17/2007 at 2:08 AM, in message
<75b4b93e0707170008t14cdcd6bv30f0b186a3015e81 at mail.gmail.com>, Umberto
Nicoletti <umberto.nicoletti at GMAIL.COM> wrote:
> I thought I had enabled agg support and I find out only now that
> mapserver configure script fails to detect my agg installation unless
> I use this option:
> --with-agg=/usr
> Is this the expected behaviour?
> I am on ubuntu feisty (32 bit).
> Umberto
> On 7/17/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Folks,
>> I updated mapagg.cpp to build. I think Umberto changed the symbolset but
>> this wasn't accounted for in mapagg.cpp.
>> I also removed some unused variables, and fixed C++ initializer order
>> related warnings.
>> But there are still several warnings left:
>> mapagg.cpp: In function `void msDrawMarkerSymbolAGGEllipse(symbolObj*,
> double,
>> double, double, char, styleObj*, int, int, int, int, gdImage*, pointObj*)':
>> mapagg.cpp:535: warning: passing `double' for converting 7 of `void
>> gdImageFilledArc(gdImage*, int, int, int, int, int, int, int, int)'
>> mapagg.cpp:536: warning: passing `double' for converting 7 of `void
>> mapagg.cpp:540: warning: passing `double' for converting 7 of `void
>> mapagg.cpp: In function `void msDrawMarkerSymbolAGGVector(symbolObj*,
> double,
>> double, double, char, styleObj*, int, int, int, int, gdImage*, pointObj*,
>> imageObj*)':
>> mapagg.cpp:557: warning: 'width' might be used uninitialized in this
> function
>> mapagg.cpp: In function `void msDrawMarkerSymbolAGG(symbolSetObj*,
> imageObj*,
>> pointObj*, styleObj*, double)':
>> mapagg.cpp:687: warning: 'offset_x' might be used uninitialized in this
> function
>> mapagg.cpp:687: warning: 'offset_y' might be used uninitialized in this
> function
>> mapagg.cpp:689: warning: 'd' might be used uninitialized in this function
>> mapagg.cpp: At global scope:
>> mapagg.cpp:331: warning: 'void imageFilledPolygon2(imageObj*, shapeObj*,
>> colorObj*, int, int)' defined but not used
>> mapagg.cpp:904: warning: 'nmsTransformShapeAGG' defined but not used
>> Several of these seem fairly serious. For instance width, offset_x and
>> offset_y seem to be used variables but never set anywhere!
>> I'd appreciate the module authors reviewing them carefully and
>> addressing them so we have a fairly clean build.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | President OSGeo, http://osgeo.org
