Call for vote on MS-RFC-17: Dynamic allocation of symbols,
layers, etc.
Daniel Morissette
dmorissette at MAPGEARS.COM
Wed Jul 18 09:20:40 EDT 2007
Thanks Tamas for the explanation about the size of the array in the
vtables stuff. I'll keep that in mind as I work on this.
Note to everyone: MS-RFC-17 has been adopted with +1 votes from DanielM,
SteveL, FrankW, SteveW, UmbertoN, TamasS, AssefaY.
I am in the process of implementing it now. The tracking bug is
https://trac.osgeo.org/mapserver/ticket/302
Daniel
Tamas Szekeres wrote:
> +1
> The mappluginlayer stuff should be concretized a bit. That static
> repository of the vtables would prevent from loading the same library
> twice. That array should also be allocated dynamically since I don't
> think we will ever have MS_MAXLAYERS number of different plugin
> layers.
> Best regards,
> Tamas
> 2007/7/13, Daniel Morissette <dmorissette at mapgears.com>:
>> I would like to call for a vote to adopt MS-RFC-17 Dynamic Allocation of
>> layers, styles, classes and symbols for implementation in MapServer 5.0:
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-17
>> I open the vote with my +1.
>> Note: Based on feedback from Frank and Umberto, it doesn't seem that the
>> potential backwards compatibility issue related to bypassing the
>> insert/add methods in SWIG MapScript is still current, so I have moved
>> this item out of the "backwards compatibility section" of RFC-17.
>> However I kept it for reference in the "Questions from the review
>> period" at the end of the RFC.
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
Daniel Morissette
