Questions re. 5.0.0-beta1
Tamas Szekeres szekerest at GMAIL.COM
Fri Jul 27 11:13:11 EDT 2007
Mike,
IIRC the issue with the 64 bit platform have already been maifested in
this list, but it seems I've neglected that a bit or I haven't managed
to set up a proper environment to reproduce the problem.
You should create a separate ticket on each problem and attach the
error message you get during the make.  Then I'll take care of the
problems ASAP.
Best regards,
Tamas
2007/7/27, Mike Leahy <mgleahy at golden.net>:
> Hello List,
> I gave beta1 a try just now on F7-64bit, and FC6-32bit.  Everything
> looks good as far as I can tell, though I have one quick question, plus
> a couple build issues with the csharp mapscript library to ask about.
> First...I recall class/style-level transparency was on the todo list for
> 5.0 - did this make it in?  If so, is there any documentation I can find
> about it?
> Regarding the csharp library, I was able to successfully compile this on
> both 64 and 32 bit (though it took me a while to realize it now uses
> 'OSGeo.MapServer' as a namespace).  However, I've found that including
> either '--enable-coverage' or '--with-fastcgi=/usr' in the MapServer
> configure options will cause make to fail when building the csharp
> library (this was already the case with the fastcgi option in 4.x...but
> I think the coverage option is new).  Also, after mapscript_csharp is
> successfully compiled (after configuring without the above two options),
> I find that 'make test' fails when run on my 64-bit machine, while on
> the 32-bit machine it works perfectly fine (this was also an issue I
> recently had with mapserver 4.x).
> Despite these small obstacles, it seems that I am still able to use the
> library to compile and run my own csharp application on 64-bit (as well
> as 32-bit), regardless of the make test results.  I'm not sure if these
> issues would be of imminent concern to any of the developers, but if so,
> let me know if there is anything in particular I can do to help shed
> light on their cause.
> Regards,
> Mike
