Thoughts on a mapserver-config script...
Frank Warmerdam
warmerdam at POBOX.COM
Wed Jun 6 11:21:50 EDT 2007
Steve Lime wrote:
> I checked on how GDAL did this and copied that process over to mapserver in
> the main branch. Doing a 'make' will create a mapserver-config script now
> although it likely needs tweaking...
Steve,
This looks promising on a preliminary review.
I notice that "mapserver-config --libs" does not include -lmap. Shouldn't it?
I also think the value of this is somewhat limited yet since we don't have
a concept of installing mapserver yet. So we can't actually point things
at the installed location of the mapserver library (or include files).
Also, I think a config switch that reports the full version string like
the following would be nice. Though I can't see exactly how this would
be accomplished without some substantial changes since this is normally
constructed based on macros in maperror.c.
OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
