Thoughts on a mapserver-config script...
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Jun 6 12:03:25 EDT 2007
It would also be very cool if the script could spit out only the
-DXXXX params for usage with swig.
Umberto
On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Steve Lime wrote:
> > I checked on how GDAL did this and copied that process over to mapserver in
> > the main branch. Doing a 'make' will create a mapserver-config script now
> > although it likely needs tweaking...
> Steve,
> This looks promising on a preliminary review.
> I notice that "mapserver-config --libs" does not include -lmap. Shouldn't it?
> I also think the value of this is somewhat limited yet since we don't have
> a concept of installing mapserver yet. So we can't actually point things
> at the installed location of the mapserver library (or include files).
> Also, I think a config switch that reports the full version string like
> the following would be nice. Though I can't see exactly how this would
> be accomplished without some substantial changes since this is normally
> constructed based on macros in maperror.c.
> OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
> INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
