Thoughts on a mapserver-config script...
Tamas Szekeres
szekerest at GMAIL.COM
Wed Jun 6 13:02:32 EDT 2007
Umberto,
Isn't that Daniel's comments at
http://trac.osgeo.org/mapserver/ticket/1884 may be relevant to this
demand?
Tamas
2007/6/6, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> It would also be very cool if the script could spit out only the
> -DXXXX params for usage with swig.
> Umberto
> On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Steve Lime wrote:
> > > I checked on how GDAL did this and copied that process over to mapserver in
> > > the main branch. Doing a 'make' will create a mapserver-config script now
> > > although it likely needs tweaking...
> > Steve,
> > This looks promising on a preliminary review.
> > I notice that "mapserver-config --libs" does not include -lmap. Shouldn't it?
> > I also think the value of this is somewhat limited yet since we don't have
> > a concept of installing mapserver yet. So we can't actually point things
> > at the installed location of the mapserver library (or include files).
> > Also, I think a config switch that reports the full version string like
> > the following would be nice. Though I can't see exactly how this would
> > be accomplished without some substantial changes since this is normally
> > constructed based on macros in maperror.c.
> > OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
> > INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | President OSGeo, http://osgeo.org
