Thoughts on a mapserver-config script...
Sean Gillies sgillies at FRII.COM
Wed Jun 6 19:09:31 EDT 2007
Amen.
Howard Butler wrote:
> -lmapserver instead of -lmap, IMO.  This is the time to do it.
> Howard
> On Jun 6, 2007, at 12:02 PM, Tamas Szekeres wrote:
>> Umberto,
>> Isn't that Daniel's comments at
>> http://trac.osgeo.org/mapserver/ticket/1884 may be relevant to this
>> demand?
>> Tamas
>> 2007/6/6, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
>>> It would also be very cool if the script could spit out only the
>>> -DXXXX params for usage with swig.
>>> Umberto
>>> On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
>>>> Steve Lime wrote:
>>>>> I checked on how GDAL did this and copied that process over to
>>> mapserver in
>>>>> the main branch. Doing a 'make' will create a mapserver-config
>>> script now
>>>>> although it likely needs tweaking...
>>>> Steve,
>>>> This looks promising on a preliminary review.
>>>> I notice that "mapserver-config --libs" does not include -lmap.
>>> Shouldn't it?
>>>> I also think the value of this is somewhat limited yet since we
>>> don't have
>>>> a concept of installing mapserver yet.  So we can't actually
>>> point things
>>>> at the installed location of the mapserver library (or include
>>> files).
>>>> Also, I think a config switch that reports the full version
>>> string like
>>>> the following would be nice.  Though I can't see exactly how
>>> this would
>>>> be accomplished without some substantial changes since this is
>>> normally
>>>> constructed based on macros in maperror.c.
>>>>   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
>>> SUPPORTS=PROJ
>>>> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER
>>> SUPPORTS=WCS_SERVER
>>>> INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
>>>> Best regards,
