Thoughts on a mapserver-config script...
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Wed Jun 6 18:59:57 EDT 2007
+1 on that.
	-----Original Message-----
	From: UMN MapServer Developers List on behalf of Howard Butler
	Sent: Wed 06-Jun-07 18:42
	To: MAPSERVER-DEV at LISTS.UMN.EDU
	Cc:
	Subject: Re: [UMN_MAPSERVER-DEV] Thoughts on a mapserver-config script...
	-lmapserver instead of -lmap, IMO.  This is the time to do it.
	Howard
	On Jun 6, 2007, at 12:02 PM, Tamas Szekeres wrote:
	> Umberto,
	> Isn't that Daniel's comments at
	> http://trac.osgeo.org/mapserver/ticket/1884 may be relevant to this
	> demand?
	> Tamas
	> 2007/6/6, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
	>> It would also be very cool if the script could spit out only the
	>> -DXXXX params for usage with swig.
	>> Umberto
	>> On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
	>> > Steve Lime wrote:
	>> > > I checked on how GDAL did this and copied that process over to
	>> mapserver in
	>> > > the main branch. Doing a 'make' will create a mapserver-config
	>> script now
	>> > > although it likely needs tweaking...
	>> > Steve,
	>> > This looks promising on a preliminary review.
	>> > I notice that "mapserver-config --libs" does not include -lmap.
	>> Shouldn't it?
	>> > I also think the value of this is somewhat limited yet since we
	>> don't have
	>> > a concept of installing mapserver yet.  So we can't actually
	>> point things
	>> > at the installed location of the mapserver library (or include
	>> files).
	>> > Also, I think a config switch that reports the full version
	>> string like
	>> > the following would be nice.  Though I can't see exactly how
	>> this would
	>> > be accomplished without some substantial changes since this is
	>> normally
	>> > constructed based on macros in maperror.c.
	>> >   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
	>> SUPPORTS=PROJ
	>> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER
	>> SUPPORTS=WCS_SERVER
	>> > INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
	>> > Best regards,
	>> > I set the clouds in motion - turn up   | Frank Warmerdam,
	>> > light and sound - activate the windows | http://pobox.com/
	>> ~warmerdam
	>> > and watch the world go round - Rush    | President OSGeo, http:// <http:///>
	>> osgeo.org
