Thoughts on a mapserver-config script...
Howard Butler
hobu.inc at GMAIL.COM
Wed Jun 6 18:42:42 EDT 2007
-lmapserver instead of -lmap, IMO. This is the time to do it.
Howard
On Jun 6, 2007, at 12:02 PM, Tamas Szekeres wrote:
> Umberto,
> Isn't that Daniel's comments at
> http://trac.osgeo.org/mapserver/ticket/1884 may be relevant to this
> demand?
> Tamas
> 2007/6/6, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
>> It would also be very cool if the script could spit out only the
>> -DXXXX params for usage with swig.
>> Umberto
>> On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> > Steve Lime wrote:
>> > > I checked on how GDAL did this and copied that process over to
>> mapserver in
>> > > the main branch. Doing a 'make' will create a mapserver-config
>> script now
>> > > although it likely needs tweaking...
>> > Steve,
>> > This looks promising on a preliminary review.
>> > I notice that "mapserver-config --libs" does not include -lmap.
>> Shouldn't it?
>> > I also think the value of this is somewhat limited yet since we
>> don't have
>> > a concept of installing mapserver yet. So we can't actually
>> point things
>> > at the installed location of the mapserver library (or include
>> files).
>> > Also, I think a config switch that reports the full version
>> string like
>> > the following would be nice. Though I can't see exactly how
>> this would
>> > be accomplished without some substantial changes since this is
>> normally
>> > constructed based on macros in maperror.c.
>> > OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
>> SUPPORTS=PROJ
>> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER
>> SUPPORTS=WCS_SERVER
>> > INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
>> > Best regards,
>> > I set the clouds in motion - turn up | Frank Warmerdam,
>> > light and sound - activate the windows | http://pobox.com/
>> ~warmerdam
>> > and watch the world go round - Rush | President OSGeo, http://
>> osgeo.org
