Thoughts on a mapserver-config script...
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Jun 7 02:42:04 EDT 2007
On 6/7/07, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> It does now via mapserver-config --defines
Sorry, but I can't find it.
Am I missing something obvious here?
Umberto
> Steve
> >>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 06/06/07 11:03 AM >>>
> It would also be very cool if the script could spit out only the
> -DXXXX params for usage with swig.
> Umberto
> On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Steve Lime wrote:
> > > I checked on how GDAL did this and copied that process over to mapserver in
> > > the main branch. Doing a 'make' will create a mapserver-config script now
> > > although it likely needs tweaking...
> > Steve,
> > This looks promising on a preliminary review.
> > I notice that "mapserver-config --libs" does not include -lmap.  Shouldn't it?
> > I also think the value of this is somewhat limited yet since we don't have
> > a concept of installing mapserver yet.  So we can't actually point things
> > at the installed location of the mapserver library (or include files).
> > Also, I think a config switch that reports the full version string like
> > the following would be nice.  Though I can't see exactly how this would
> > be accomplished without some substantial changes since this is normally
> > constructed based on macros in maperror.c.
> >   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
> > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
> > INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> > Best regards,
> > I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush    | President OSGeo, http://osgeo.org
