Thoughts on a mapserver-config script...
Tamas Szekeres szekerest at GMAIL.COM
Thu Jun 7 03:19:08 EDT 2007
Umberto,
My primary intention with that ticket was to remove the explicit
duplication of the various libraries in the csharp Makefile.in like:
PROJ_INC= @PROJ_INC@
PROJ_LIBS= @PROJ_LIBS@
PROJ=     @PROJ_ENABLED@
that should not be needed. The actual solution requires to make some
additional efforts to keep the csharp and the core makefile in sync.
I think we might have a different selection of the defines to compile
the core mapserver related stuff than to pass the variables to the
SWIG command line.
Best regards,
Tamas
2007/6/7, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> On 6/6/07, Tamas Szekeres <szekerest at gmail.com> wrote:
> > Umberto,
> > Isn't that Daniel's comments at
> > http://trac.osgeo.org/mapserver/ticket/1884 may be relevant to this
> > demand?
> Yes they are.
> My point is that some laguages like perl, python and ruby do not have
> makefiles and at the moment they resort to reading the mapscriptvars
> file, while java and csharp do have a Makefile and if mapserver-config
> could have an option to just output the same defines that go into
> mapscriptvars we could think of a way of unifying the whole process.
> The mapserver-config could even do something as simple as:
> head -2 < mapscriptvars | tail -1
> to get the needed swig defines. Of course if mapserver-config is to be
> installed somewhere like /usr/local it must know where to find the
> mapscriptvars file.
> The alternative is to add the substitution of ALL_ENABLED like
> suggested in #1884.
> This also raises the question if mapscriptvars is still needed and if
> mapserver-config should replace it.
> Umberto
> > Tamas
> > 2007/6/6, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> > > It would also be very cool if the script could spit out only the
> > > -DXXXX params for usage with swig.
> > > Umberto
> > > On 6/6/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > > > Steve Lime wrote:
> > > > > I checked on how GDAL did this and copied that process over to mapserver in
> > > > > the main branch. Doing a 'make' will create a mapserver-config script now
> > > > > although it likely needs tweaking...
> > > > Steve,
> > > > This looks promising on a preliminary review.
> > > > I notice that "mapserver-config --libs" does not include -lmap.  Shouldn't it?
> > > > I also think the value of this is somewhat limited yet since we don't have
> > > > a concept of installing mapserver yet.  So we can't actually point things
> > > > at the installed location of the mapserver library (or include files).
> > > > Also, I think a config switch that reports the full version string like
> > > > the following would be nice.  Though I can't see exactly how this would
> > > > be accomplished without some substantial changes since this is normally
> > > > constructed based on macros in maperror.c.
> > > >   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
> > > > SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
> > > > INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> > > > Best regards,
> > > > I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> > > > light and sound - activate the windows | http://pobox.com/~warmerdam
> > > > and watch the world go round - Rush    | President OSGeo, http://osgeo.org
