draw a layer with labels but no pointsymbols
Hallgren Johan E
jhhal at WMDATA.COM
Wed Jun 13 15:21:44 EDT 2007
Sounds too easy :)
I will try it.
Thanks
/Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Steve Lime
Sent: den 13 juni 2007 16:18
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] draw a layer with labels but no
pointsymbols
Johan: If you want just labels use TYPE ANNOTATION...
Steve
>>> On 6/13/2007 at 8:24 AM, in message
<D93CFEAA72FA764885CC1FDA94A1D89C02D16E91 at WMRI000166.corp.wmdata.net>,
Hallgren
Johan E <jhhal at WMDATA.COM> wrote:
> I have had some troubles drawing a layer only with labels, and no
> points. I hade to use an empty STYLE-tag (see below), otherwise the
> image wasn't generated.
> It's a bit strange to use an empty tag in that situation, and it was
> hard to find the problem.
> These two examples works:
> LAYER
> NAME "31"
> TYPE POINT
> DATA "C:\TEMP\SVEASKOG\data\PPL_TRK_P.shp"
> STATUS OFF
> CLASS
> TEXT '8'
> LABEL
> COLOR 255 0 0
> TYPE TRUETYPE
> FONT Verdana
> SIZE 18
> END
> STYLE
> END
> END
> END
> LAYER
> NAME "32"
> TYPE POINT
> FEATURE
> POINTS
> 100 100
> END
> END
> TRANSFORM false
> STATUS ON
> CLASS
> TEXT '8'
> LABEL
> COLOR 255 0 0
> TYPE TRUETYPE
> FONT Verdana
> SIZE 18
> END
> STYLE
> END
> END
> END
> But not these
> LAYER
> NAME "31"
> TYPE POINT
> STATUS OFF
> CLASS
> TEXT '8'
> LABEL
> COLOR 255 0 0
> TYPE TRUETYPE
> FONT Verdana
> SIZE 18
> END
> END
> END
> LAYER
> NAME "32"
> TYPE POINT
> FEATURE
> POINTS
> 100 100
> END
> END
> TRANSFORM false
> STATUS ON
> CLASS
> TEXT '8'
> LABEL
> COLOR 255 0 0
> TYPE TRUETYPE
> FONT Verdana
> SIZE 18
> END
> END
> END
> /Johan
> Johan Hallgren
> Pelle Bergs backe 3
> <BLOCKED::mailto:johan.e.hallgren at wmdata.com>
> <BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
