Re-thinking RFC 6
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Jun 14 22:59:52 EDT 2007
Hi guys: As the deadline for RFC's approaches I wanted to float a change to RFC 6 that might be doable by 5.0. I've not spent time updating the RFC yet. The idea would be to bind properties to ranges much like RFC 19. We'd extend the range concept to colors, sizes and angles. So COLORRANGE would become RANGE. RANGEs would live at the layer level and would be referenced by name so you could have several.
A range would be defined as:
typedef struct {
char *name;
attributeBindingObj item; /* holds name and index */
colorObj mincolor, maxcolor; /* only colorObj's and numbers make sense */
double minnumber, maxnumber;
double minvalue, maxvalue;
int intervals;
int method; /* should be enum - MS_RANGE_METHOD */
} rangeObj;
and a layer would have an array (fixed size, might be ok, should need more than a couple, or dynamic) of these.
Styles properties (color, outlinecolor, size, angle) could then reference these by name.
e.g.
LAYER
NAME 'myLayer'
RANGE
NAME 'sizeRange'
ITEM 'sizeitem'
MINNUMBER 1
MAXNUMBER 10
MINVALUE 1000.0
MAXVALUE 500000.0
END
CLASS
STYLE
SYMBOL 'square'
COLOR 50 255 50
SIZE {sizeRange}
END
END
END
{}'s (or some other delimiter) define a range binding. Could even support a range function longer term. I just like the idea of a more general range solution. Thoughts?
Steve
