Re-thinking RFC 6
Frank Warmerdam warmerdam at POBOX.COM
Fri Jun 15 00:18:25 EDT 2007
Steve Lime wrote:
> Hi guys: As the deadline for RFC's approaches I wanted to float a change to RFC 6 that might be doable by 5.0. I've not spent time updating the RFC yet. The idea would be to bind properties to ranges much like RFC 19. We'd extend the range concept to  colors, sizes and angles. So COLORRANGE would become RANGE. RANGEs would live at the layer level and would be referenced by name so you could have several.
> A range would be defined as:
> typedef struct {
>   char *name;
>   attributeBindingObj item; /* holds name and index */
>   colorObj mincolor, maxcolor; /* only colorObj's and numbers make sense */
>   double minnumber, maxnumber;
>   double minvalue, maxvalue;
>   int intervals;
>   int method; /* should be enum - MS_RANGE_METHOD */
> } rangeObj;
> and a layer would have an array (fixed size, might be ok, should need more than a couple, or dynamic) of these.
> Styles properties (color, outlinecolor, size, angle) could then reference these by name.
> e.g.
> LAYER
>   NAME 'myLayer'
>   RANGE
>     NAME 'sizeRange'
>     ITEM 'sizeitem'
>     MINNUMBER 1
>     MAXNUMBER 10
>     MINVALUE 1000.0
>     MAXVALUE 500000.0
>   END
Steve,
I sort of like this approach though it seems like substantial
machinery might be needed to support it.
I also really think that you need to make it more clear what are
input values and what are output values. Perhaps min_in_val,
max_in_val, min_out_scalar, max_out_scalar.  For me "value" and
"number" are too general to work out which is input and output
of the function.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
