Re-thinking RFC 6
Frank Warmerdam
warmerdam at POBOX.COM
Fri Jun 15 11:02:09 EDT 2007
Daniel Morissette wrote:
> Jan Hartmann wrote:
>> Perhaps converting the start and end color to HSV (Hue, Saturation,
>> Value) would give values that could be interpolated in a meaningful way.
>> For display, the interpolated colors could be converted back to RGB. The
>> algorithm is elementary, i believe.
> I don't know if interpolating on HSV is enough. Doing a quick Google
> search turned up this page:
> http://ozviz.wasp.uwa.edu.au/~pbourke/texture_colour/colourramp/
Folks,
I do agree with Daniel that single ramps will not ultimately satisfy
all requirements. We could take an approach like RFC 21
http://mapserver.gis.umn.edu/development/rfc/ms-rfc-21/
RFC 21 specifies a list of input and output values which are interpolated
to define a curve.
<lut_specification>=<in_value>:<out_value>,<in_value>:<out_value>[,<in_value>:<out_value>]*
resulting in stuff like:
PROCESSING "LUT=0:0,128:150,255:255"
Or we could just declare that for now linear ranges are a big step forward,
and address non-linear ranges later.
Steve Lime wrote:
> I agree on the naming. Will have to ponder that. I'd like an syntax that
would accommodate colors and numbers in the same way:
> PARAMETERLIMITS #FFFFFF #FF0000 or PARAMETERRANGE 1 10
> (we can handle that in mapfile.c) and then
> ITEMLIMITS 1000.0 50000.0
This sounds pretty good to me. Do we use the #FF0000 syntax for
colors anywhere else?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
