MS RFC 28: Redesign of LOG/DEBUG output mechanisms
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Jun 15 12:13:09 EDT 2007
Tamas Szekeres wrote:
> Daniel,
> As far as I can understand you propose to keep a global variable that
> will be set in msSetup() (if the environment variable is set) and
> might be modified when each mapfile is parsed. How this implementation
> would work in a multithreaded environment? For example when handling
> one request would open /tmp/mapserver1.log while another would use
> /tmp/mapserver2.log.
> In addition I wonder how the open file handles are reusable by
> multiple threads in the various environments.
I guess I didn't make that clear in the RFC, but my intention was to
have the file handle global for a given request only, but not global
across threads. I plan to do that by using the same mechanism that we
already use in msGetErrorObj() (maperror.c) to have a single error stack
per thread. Since this code seems to have worked well for a while I
didn't expect any issue with handling the file handle the same way.
> It would be pretty useful to support the Windows OutputDebugString API
> as well. That would make the life of the Windows developers much
> easier and establish the ability to use external programs like
> SysInternals debugview to display the debug output. (I think there
> have been some issues in the -users list in this question before) For
> using this function <windows.h> should be included which have already
> included in many places in the code.
Can you provide a code sample that shows the use of OutputDebugString?
Could it be as simple as having another special keyword for the
MS_ERRORFILE value, for instance "windowsdebug", that sends output to
this system? If the mechanism works in a similar way as writing to a
file and doesn't require changing too much stuff and you can provide
code samples that use it then I'm willing to try including this in the RFC.
Daniel
Daniel Morissette
http://www.mapgears.com/
