Using the "C API" and modifying the projection...
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Jun 21 11:16:52 EDT 2007
Wheeeeewwwweeewww... all those "cout << ... << ... << ..."  make my head
spin counterclockwise!  ;) ;)
If my internal interpreter recovered from all that spinning and ran your
code correctly, I suspect your problem may be related to the way you try
to make a copy of map->projection in 'in':
    msInitProjection( &in );
    in = map->projection;
Since this is a C API and not C++ classes, assigning in=map->projection
like this is asking for trouble. The projectionObj contains some
pointers to allocated buffers and/or data structures that won't be
copied by this assignment so you end up with a half copy. I think it
would be safer to use a "projectionObj *in" which would make it clear
that you are just carrying a ref to map->projection and not trying to
make a copy... or just don't bother using 'in' and use map->projection
explicitly everywhere.
I think what may be happening here is that the call to
msLoadProjectionString(&map->projection,msGetProjectionString(projOut));
  later on overwrites some of the contents of 'in' which are really data
structures owned by map->projection and not by 'in'.
I suspect that moving the call to
to a line after you have reprojected the extents might resolve the
issue. But the correct fix would be to not try to make that half-copy of
map->projection in 'in' as I explained above.
Of course I could be plain wrong on this... my head is still spinning...
wheeewweew  << ewwww << eewww << ... ;)
Daniel
Ian Erickson wrote:
> Gentlemen,
> I know that the C API was never really intended for use directly as a
> developer's platform, although when evaluating all of my options it was
> clear that what I needed to do was simple and the C API (map.h,
> mapproject.h) were ideal for my situation....however....
> I've put together a simple console application to test the API and
> (whatever I try) I cannot get the map to change projections and specify
> the extent of the new map in projected coordinates.
> Here's an extract...
> void simpleMap( double minx = -180.0, double miny = -90.0, double maxx =
> 180.0, double maxy = 90.0 )
>    mapObj *map = NULL;
>    imageObj *image = NULL;
>    // This map and every layer in it has the projection of epsg:4326...
>    map = msLoadMap("C:\\some.map", NULL);
>    pointObj *pt_ll = pointObj_new();
>    pointObj *pt_ur = pointObj_new();
>    // *** Assign the coordinates to be reprojected.
>    pt_ll->x = minx;
>    pt_ll->y = miny;
>    pt_ur->x = maxx;
>    pt_ur->y = maxy;
>    cout << "BEFORE:" << endl;
>    cout << "pt_ll: (" << pt_ll->x << ", " << pt_ll->y << ")" << endl;
>    cout << "pt_ur: (" << pt_ur->x << ", " << pt_ur->y << ")" << endl;
>    cout << endl;
>    // *** Just to confirm, that the mapObj is working as expected, I
> test this statement and indeed,
>    // *** the map is recentered correctly....
>    msMapSetExtent( map, pt_ll->x, pt_ll->y, pt_ur->x, pt_ur->y );
>    // *** Create projectionObj pointers to convert between geographic
> coordinates
>    // *** into the Transverse Mercator projection required for USGS quads.
>    // *** projectionObj_new is defined elsewhere and functions
> properly...as the
>    // *** transformed coordinates are correct.
>    projectionObj *projIn = projectionObj_new( "+init=epsg:4326" );
>    string s_projOut = "+proj=tmerc +lat_0=0.0";
>    s_projOut.append( " +lon_0=" );
>    s_projOut.append( doubleToString( (double)((pt_ll->x + pt_ur->x) /
> 2.0) ) );
>    s_projOut.append( " +k=0.9996 +x_0=0.0 +y_0=0.0 +ellps=GRS80" );
>    projectionObj *projOut = projectionObj_new( _strdup(
> s_projOut.c_str() ) );
>    cout << "Output Projection: " << msGetProjectionString( projOut ) <<
> endl;
>    // *** Reproject the input points.  One point for the lower-left
> coordinate
>    // *** and one for the upper-right corner.
>    msProjectPoint( projIn, projOut, pt_ll );
>    msProjectPoint( projIn, projOut, pt_ur );
>    // *** These points are correct! No problem here....
>    cout << "AFTER: " << endl;
>    cout << "p_min: (" << pt_ll->x << ", " << pt_ll->y << ")" << endl;
>    cout << "p_max: (" << pt_ur->x << ", " << pt_ur->y << ")" << endl;
>    cout << endl;
>    // *** This is where things fall apart.  Taking a page from the
> php_mapscript.c and
>    // *** mapscript_i.c sources, I init the projectionObj pointers, run
> msLoadProjectionString,
>    // *** and recompure the extent of the map....msLoadProjectionString
> by itself doesn't work either.
>    int nStatus = 0;
>    int nUnits = MS_METERS;
>    projectionObj in;
>    projectionObj out;
>    rectObj sRect;
>    int bSetNewExtents = 0;
>    int bSetUnitsAndExtents = 1;
>    msInitProjection( &out );
>    msLoadProjectionString( &(out), msGetProjectionString( projOut ) );
>    sRect = map->extent;
>    if (in.proj != NULL && out.proj != NULL)
>        if (msProjectionsDiffer( &in, &out ) )
>            if (msProjectRect( &in, &out, &sRect) == 0)
>                bSetNewExtents = 1;
>    msLoadProjectionString( &map->projection, msGetProjectionString(
> projOut ) );
>    nUnits = GetMapserverUnitUsingProj( &map->projection );
>    map->units = (MS_UNITS)nUnits;
>    if (bSetNewExtents == 1)
>        map->extent = sRect;
>        map->cellsize = msAdjustExtent( &map->extent, map->width,
> map->height );
>        msCalculateScale( map->extent, map->units, map->width,
> map->height, map->resolution, &map->scale );
>    // *** Compute the size of the output map in meters.  This is later
> used to
>    // *** determine the output size of the map in pixels.
>    double width_m = pt_ur->x - pt_ll->x;
>    double height_m = pt_ur->x - pt_ll->y;
>    double width = 500.0;
>    double height = ((height_m / width_m) * width);
>    cout << "EARTH SIZE [Width, Height] m: " << ((double)width_m) << ", "
> << ((double)height_m) << endl;
>    cout << endl;
>    // *** Set the size of the output map.
>    msMapSetSize( map, (int)width, (int)height );
>    cout << "MAP SIZE [Width, Height]: " << map->width << ", " <<
> map->height << endl;
>    // *** Set the extent of the map as per the newly projected coordinates
>    // *** computed above.
>    // *** This call is where things go wrong.  Apparently the
> msLoadProjectionString is not
>    // *** working properly, because if I use the original coordinates
> supplied as parameters
>    // *** the map moves to the correct location -- not the projected
> location.
>    image = msDrawMap( map );
>    msSaveImage( map, image, "C:\\simple.png");
>    pointObj_destroy( pt_ll );
>    pointObj_destroy( pt_ur );
>    msFreeImage( image );
>    msFreeMap( map );
>    msCleanup();
>    cout << "Complete!" << endl;
> Please! I'm looking for some guidance here as it doesn't seem too
> difficult - and the same order and function calls work in PHP/MapScript!
Daniel Morissette
http://www.mapgears.com/
