Using the "C API" and modifying the projection...
Ian Erickson
ierickson at ANALYGIS.COM
Thu Jun 21 11:29:39 EDT 2007
I know, I know....
The 'c', 'o', 'u', and 't' keys are a little worse for wear on the 'ol
keyboard. Although...I seem to have found my issue.
Rule #1) Make sure that the import libraries that you're linking
against are the same DLLs that you're running with.
I had an evironment variable (for PHP) that was pointing my application
to DLLs of version 4.10.0 (not the 4.10.2 DLLs that I was building
against).
Sorry for the fire alarm everyone, but after a day of trying it's
finally working!! For the record, this is the code that does actually
work when compiled, linked....and run correctly!
mapObj *map = NULL;
imageObj *image = NULL;
msSetup();
map = msLoadMap( "C:\\original.map", NULL );
if (!map) {
cout << "There is an error loading the map..." << endl;
return;
//Trying to change the projection to epsg:4269 (and then verify it in
the output.map file)...
msLoadProjectionString( &(map->projection), "+init=epsg:4269" );
msSaveMap( map, "C:\\output.map" );
image = msDrawMap( map );
msSaveImage( map, image, "C:\\output.png" );
msFreeImage( image );
msFreeMap( map );
msCleanup();
Thanks!
Daniel Morissette wrote:
> Wheeeeewwwweeewww... all those "cout << ... << ... << ..." make my
> head spin counterclockwise! ;) ;)
> If my internal interpreter recovered from all that spinning and ran
> your code correctly, I suspect your problem may be related to the way
> you try to make a copy of map->projection in 'in':
> msInitProjection( &in );
> in = map->projection;
> Since this is a C API and not C++ classes, assigning
> in=map->projection like this is asking for trouble. The projectionObj
> contains some pointers to allocated buffers and/or data structures
> that won't be copied by this assignment so you end up with a half
> copy. I think it would be safer to use a "projectionObj *in" which
> would make it clear that you are just carrying a ref to
> map->projection and not trying to make a copy... or just don't bother
> using 'in' and use map->projection explicitly everywhere.
> I think what may be happening here is that the call to
> msLoadProjectionString(&map->projection,msGetProjectionString(projOut));
> later on overwrites some of the contents of 'in' which are really
> data structures owned by map->projection and not by 'in'.
> I suspect that moving the call to
> to a line after you have reprojected the extents might resolve the
> issue. But the correct fix would be to not try to make that half-copy
> of map->projection in 'in' as I explained above.
> Of course I could be plain wrong on this... my head is still
> spinning... wheeewweew << ewwww << eewww << ... ;)
> Daniel
> Ian Erickson wrote:
>> Gentlemen,
>> I know that the C API was never really intended for use directly as a
>> developer's platform, although when evaluating all of my options it
>> was clear that what I needed to do was simple and the C API (map.h,
>> mapproject.h) were ideal for my situation....however....
>> I've put together a simple console application to test the API and
>> (whatever I try) I cannot get the map to change projections and
>> specify the extent of the new map in projected coordinates.
>> Here's an extract...
>> void simpleMap( double minx = -180.0, double miny = -90.0, double
>> maxx = 180.0, double maxy = 90.0 )
>> mapObj *map = NULL;
>> // This map and every layer in it has the projection of epsg:4326...
>> map = msLoadMap("C:\\some.map", NULL);
>> pointObj *pt_ll = pointObj_new();
>> pointObj *pt_ur = pointObj_new();
>> // *** Assign the coordinates to be reprojected.
>> pt_ll->x = minx;
>> pt_ll->y = miny;
>> pt_ur->x = maxx;
>> pt_ur->y = maxy;
>> cout << "BEFORE:" << endl;
>> cout << "pt_ll: (" << pt_ll->x << ", " << pt_ll->y << ")" << endl;
>> cout << "pt_ur: (" << pt_ur->x << ", " << pt_ur->y << ")" << endl;
>> cout << endl;
>> // *** Just to confirm, that the mapObj is working as expected, I
>> test this statement and indeed,
>> // *** the map is recentered correctly....
>> msMapSetExtent( map, pt_ll->x, pt_ll->y, pt_ur->x, pt_ur->y );
>> // *** Create projectionObj pointers to convert between geographic
>> coordinates
>> // *** into the Transverse Mercator projection required for USGS
>> quads.
>> // *** projectionObj_new is defined elsewhere and functions
>> properly...as the
>> // *** transformed coordinates are correct.
>> projectionObj *projIn = projectionObj_new( "+init=epsg:4326" );
>> string s_projOut = "+proj=tmerc +lat_0=0.0";
>> s_projOut.append( " +lon_0=" );
>> s_projOut.append( doubleToString( (double)((pt_ll->x + pt_ur->x) /
>> 2.0) ) );
>> s_projOut.append( " +k=0.9996 +x_0=0.0 +y_0=0.0 +ellps=GRS80" );
>> projectionObj *projOut = projectionObj_new( _strdup(
>> s_projOut.c_str() ) );
>> cout << "Output Projection: " << msGetProjectionString( projOut )
>> << endl;
>> // *** Reproject the input points. One point for the lower-left
>> coordinate
>> // *** and one for the upper-right corner.
>> msProjectPoint( projIn, projOut, pt_ll );
>> msProjectPoint( projIn, projOut, pt_ur );
>> // *** These points are correct! No problem here....
>> cout << "AFTER: " << endl;
>> cout << "p_min: (" << pt_ll->x << ", " << pt_ll->y << ")" << endl;
>> cout << "p_max: (" << pt_ur->x << ", " << pt_ur->y << ")" << endl;
>> cout << endl;
>> // *** This is where things fall apart. Taking a page from the
>> php_mapscript.c and
>> // *** mapscript_i.c sources, I init the projectionObj pointers,
>> run msLoadProjectionString,
>> // *** and recompure the extent of the
>> map....msLoadProjectionString by itself doesn't work either.
>> int nStatus = 0;
>> int nUnits = MS_METERS;
>> projectionObj in;
>> projectionObj out;
>> rectObj sRect;
>> int bSetNewExtents = 0;
>> int bSetUnitsAndExtents = 1;
>> msInitProjection( &out );
>> msLoadProjectionString( &(out), msGetProjectionString( projOut ) );
>> sRect = map->extent;
>> if (in.proj != NULL && out.proj != NULL)
>> if (msProjectionsDiffer( &in, &out ) )
>> if (msProjectRect( &in, &out, &sRect) == 0)
>> bSetNewExtents = 1;
>> msLoadProjectionString( &map->projection, msGetProjectionString(
>> projOut ) );
>> nUnits = GetMapserverUnitUsingProj( &map->projection );
>> map->units = (MS_UNITS)nUnits;
>> if (bSetNewExtents == 1)
>> map->extent = sRect;
>> map->cellsize = msAdjustExtent( &map->extent, map->width,
>> map->height );
>> msCalculateScale( map->extent, map->units, map->width,
>> map->height, map->resolution, &map->scale );
>> // *** Compute the size of the output map in meters. This is
>> later used to
>> // *** determine the output size of the map in pixels.
>> double width_m = pt_ur->x - pt_ll->x;
>> double height_m = pt_ur->x - pt_ll->y;
>> double width = 500.0;
>> double height = ((height_m / width_m) * width);
>> cout << "EARTH SIZE [Width, Height] m: " << ((double)width_m) <<
>> ", " << ((double)height_m) << endl;
>> cout << endl;
>> // *** Set the size of the output map.
>> msMapSetSize( map, (int)width, (int)height );
>> cout << "MAP SIZE [Width, Height]: " << map->width << ", " <<
>> map->height << endl;
>> // *** Set the extent of the map as per the newly projected
>> coordinates
>> // *** computed above.
>> // *** This call is where things go wrong. Apparently the
>> msLoadProjectionString is not
>> // *** working properly, because if I use the original coordinates
>> supplied as parameters
>> // *** the map moves to the correct location -- not the projected
>> location.
>> msSaveImage( map, image, "C:\\simple.png");
>> pointObj_destroy( pt_ll );
>> pointObj_destroy( pt_ur );
>> msFreeMap( map );
>> msCleanup();
>> cout << "Complete!" << endl;
>> Please! I'm looking for some guidance here as it doesn't seem too
>> difficult - and the same order and function calls work in PHP/MapScript!
