MIGRATION_GUIDE.TXT
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jun 27 10:24:09 EDT 2007
Stephen Woodbridge wrote:
> I think we need to clarify this point.
>> Styling/Symbolgy changes
>> Prior to MapsServer 5.0, if a pixmap symbol was used in style on a Line
>> Layer, the symbol was used as a brush to draw the line. In MapServer 5.0,
>> it is possible to draw the pixmap symbol along the line (Note that this
>> was available using a true type symbol). To achieve this, the user needs
>> to use the parameter GAP with it's pixmap symbol definition in the symbol
>> file. The GAP represents the distance between the symbols. If the GAP
>> is not
>> given, the pixmap symbol will be used as a brush.
> With true type symbols you can specify negative values for GAP to cause
> the symbol to align with the line segment. Is this also supported for
> pixmap symbols? This should be made explicit in here.
The pixmap symbols (and the true type symbols) always align with the
line segment. The negative gap should have the effect of adding 180deg
to the calculated angle.
I will update the guide to reflect this.
> -Steve W
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
