MIGRATION_GUIDE.TXT
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Jun 27 11:29:51 EDT 2007
Yewondwossen Assefa wrote:
> Stephen Woodbridge wrote:
>> I think we need to clarify this point.
>>> Styling/Symbolgy changes
>>> Prior to MapsServer 5.0, if a pixmap symbol was used in style on a Line
>>> Layer, the symbol was used as a brush to draw the line. In MapServer
>>> 5.0,
>>> it is possible to draw the pixmap symbol along the line (Note that this
>>> was available using a true type symbol). To achieve this, the user
>>> needs
>>> to use the parameter GAP with it's pixmap symbol definition in the
>>> symbol
>>> file. The GAP represents the distance between the symbols. If the GAP
>>> is not
>>> given, the pixmap symbol will be used as a brush.
>> With true type symbols you can specify negative values for GAP to
>> cause the symbol to align with the line segment. Is this also
>> supported for pixmap symbols? This should be made explicit in here.
> The pixmap symbols (and the true type symbols) always align with the
> line segment. The negative gap should have the effect of adding 180deg
> to the calculated angle.
> I will update the guide to reflect this.
Assefa,
The current behavior is that with a positive gap, the symbol will always
point north, when the gap is negative it will align the symbol north
with the direction of the line segment. I do not think we want to
eliminate either of these options. For oneway arrows along streets, you
need to know if the direction of travel is A-B or B-A and use a CLASS to
select a flipped symbol for the other direction. You can not change the
GAP to flip the symbol on a per shape basis in the mapfile.
-Steve
>> -Steve W
