MIGRATION_GUIDE.TXT
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jun 27 13:46:59 EDT 2007
Stephen Woodbridge wrote:
> OK, I could be wrong, but this might also be a regression that was
> introduced at some point.
> Does anyone else remember what the behavior used to be with this?
> Assefa, if you have some older versions of mapserver already loaded can
> you try this on them also. If the behavior is consistent, then document
> it. And I'll try to update my memory :)
Oldest I have locally is Mapserver 4.8.x : the code in the function
seems to be the same as the one in the current svn. I will update the
docs (http://mapserver.gis.umn.edu/docs/reference/symbology) to reflect
this.
> Thanks,
> -Steve W.
>>>>> I think we need to clarify this point.
>>>>>> Styling/Symbolgy changes
>>>>>> Prior to MapsServer 5.0, if a pixmap symbol was used in style on a
>>>>>> Line
>>>>>> Layer, the symbol was used as a brush to draw the line. In
>>>>>> MapServer 5.0,
>>>>>> it is possible to draw the pixmap symbol along the line (Note that
>>>>>> this
>>>>>> was available using a true type symbol). To achieve this, the
>>>>>> user needs
>>>>>> to use the parameter GAP with it's pixmap symbol definition in the
>>>>>> symbol
>>>>>> file. The GAP represents the distance between the symbols. If the
>>>>>> GAP is not
>>>>>> given, the pixmap symbol will be used as a brush.
>>>>> With true type symbols you can specify negative values for GAP to
>>>>> cause the symbol to align with the line segment. Is this also
>>>>> supported for pixmap symbols? This should be made explicit in here.
>>>> The pixmap symbols (and the true type symbols) always align with
>>>> the line segment. The negative gap should have the effect of adding
>>>> 180deg to the calculated angle.
>>>> I will update the guide to reflect this.
>>> Assefa,
>>> The current behavior is that with a positive gap, the symbol will
>>> always point north, when the gap is negative it will align the symbol
>>> north with the direction of the line segment. I do not think we want
>>> to eliminate either of these options. For oneway arrows along
>>> streets, you need to know if the direction of travel is A-B or B-A
>>> and use a CLASS to select a flipped symbol for the other direction.
>>> You can not change the GAP to flip the symbol on a per shape basis in
>>> the mapfile.
>> Steve,
>> I am not sure that when using a true type fonts, a positive gap will
>> always make the symbol point north. Here is a test I did with a true
>> type font :
>> SYMBOL
>> NAME "I"
>> TYPE
>> TRUETYPE
>> FONT "Arial"
>> CHARACTER "I"
>> ANTIALIAS TRUE
>> GAP 15
>> END
>> and the STYLE looks
>> STYLE
>> SYMBOL "I"
>> SIZE 15
>> COLOR 120 120 120
>> END
>> Attached is the a what it gives in Mapserver
>> Looking at the result, I interpret this as being the symbol is
>> aligned with the line and does not always point north. Is that correct ?
>>> -Steve
>>>>> -Steve W
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
