MS RFC 22a: Feature cache for long running processes and
query processing (update)
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Jun 28 13:00:48 EDT 2007
I think you start bleeding over into a full-blown feature cache as described. That's kinda why I
was thinking of using the resultcache. You wouldn't even need msGetShape then, the shape
would be there for you as you rolled through the feature cache...
(deadline, schmeadline)
Steve
>>> On 6/28/2007 at 10:38 AM, in message <4683D5FA.9030808 at pobox.com>, Frank
Warmerdam <warmerdam at POBOX.COM> wrote:
> Tamas Szekeres wrote:
>> 2007/6/28, Steve Lime <Steve.Lime at dnr.state.mn.us>:
>>> I think the easiest way to achieve one-pass queries would be to simply
>>> re-tool the result set structure to store a pile of features (linked
>>> list or other) in
>>> memory. The id cache could be maintained for memory constrained
>>> situations.
>> Steve,
>> I'm not totally sure about that. Then you should probably reimplement
>> all of the functions involved in the layerObj->results member. At
>> least the following files might be affected:
>> mapdraw.c
>> mapquery.c
>> mapgml.c
>> mapogcfilter.c
>> mapogcsos.c
>> maprasterquery.c
>> maptemplate.c
>> mapwms.c
>> And it's quite difficult even to count the existing functions to be
>> modified. I guess it's
>> a large amount of work to implement this as well as fixing the bugs it
>> involves.
> Steve / Tamas,
> In my opinion, if we wanted a minimum complexity solution we would
> add a mechanism to store cached features in the layer structure,
> and just modify the query code to push them into this cache, and
> the msGetShape() function to fetch them - avoiding going into any
> provider specific logic at all. The resultcache would stay unaltered,
> but msGetShape() would first check the feature cache.
> I'm not sure if there would be auto-styling issues with this approach
> though since it would mostly just be used for query results I think
> it would be ok.
> I'd be prepared to write an RFC for this approach if we decide
> against RFC 22a, though we are past our MapServer 5.0 RFC deadline.
> In fact, I'm quite concerned about implementing something as big and
> complex as RFC 22a in our last few weeks before release. It doesn't
> really leave very long for things to settle down in the development
> tree.
> Best regards,
