MS RFC 22a: Feature cache for long running processes and
query processing (update)
Frank Warmerdam
warmerdam at POBOX.COM
Fri Jun 29 15:34:24 EDT 2007
Steve Lime wrote:
> Regarding RFC 22 what do folks think about implementing a simple one-pass cache using
> the resultCacheMemberObj for 5.0? Then considering RFC 22 independently of queries independently
> since there are plenty of good ideas there.
Steve,
I feel this would be prudent.
Earlier you wrote:
> The result cache is nothing more than an array of those members.
> (e.g. layer->results) That could be made more high performance and
> hidden behind accessor methods in mapscript. Users use getResult(int i)
> already.
I *think* this was in response to my claim that your approach would
mean all the mapscript scripts would be changed. When I read it I
said "aha - my concern is moot". But now that I review my one and only
mapscript script with queries I see that getResult() is just pulling
back the shapeindex and tileindex which I still pass to getShape().
So I still don't see how you can do your proposed change without
all mapscript scripts's approach to queries having to change.
Am I missing something still?
PS. My sample bit of script reads:
def dumpResultSet( layer ):
layer.open()
for i in range(1000):
result = layer.getResult( i )
if result is None:
break
print '(%d,%d)' % (result.shapeindex, result.tileindex)
s = layer.getFeature( result.shapeindex, result.tileindex )
for i in range(layer.numitems):
print '%s: %s' % (layer.getItem(i), s.getValue(i))
layer.close()
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
