MS RFC 22a: Feature cache for long running processes and
query processing (update)
Howard Butler
hobu.inc at GMAIL.COM
Fri Jun 29 15:22:40 EDT 2007
Steve,
The SDE driver in trunk now gets all of the items all of the time.
The WhichItems approach wasn't really feasible once I started putting
joins in play (items are appended to the list if they are not found,
causing a segfault because the items now mismatch the internal
columns list that is maintained...). If I recall correctly, you said
the SDE driver was the reason WhichItems existed in the first place.
If the surgery to remove it isn't too difficult, I think we should
take the opportunity to ditch it.
Howard
On Jun 29, 2007, at 2:11 PM, Steve Lime wrote:
> The one gotcha with one-pass queries regardless of approach is that
> presently the items
> retrieved for the first pass don't match those on the second pass.
> In the first pass we grab just
> enough to classify (if necessary) features via msLayerWhichItems.
> While the second pass gets
> all items for presentation. We really should ditch
> msLayerWhichItems and get all items all the
> time.
> The main impact of that would be needing to derive item (e.g.
> classitem, labelitem, etc...) index
> values at runtime. Basically:
> if (classitem && classitemindex == -1) /* lookup */
> classitemindex = msLayerGetItemIndexByName(...);
> if(classitemindex == -1) { /* item not found, throw an error */
> This would affect a few places in the code, principally mapdraw.c
> and maputil.c.
> The initItemInfo functions for each of the vector drivers might
> need changes, although I hope
> minor ones since we already support getting all items.
> In reality this is a simplification of things which is a good
> thing. I would be willing to take this modification
> on in consultation with driver owners.
> Regarding RFC 22 what do folks think about implementing a simple
> one-pass cache using
> the resultCacheMemberObj for 5.0? Then considering RFC 22
> independently of queries independently
> since there are plenty of good ideas there.
> Steve
>>>> On 6/28/2007 at 12:55 PM, in message <4683F62D.
>>>> 7070401 at mapgears.com>, Daniel
> Morissette <dmorissette at MAPGEARS.COM> wrote:
>> Steve Lime wrote:
>>> That could be as simple as the shape just sitting there along
>>> with the
>> indexes, that is, the
>>> resultCacheMemberObj gets a new member, a shapeObj.
>>> The result cache is nothing more than an array of those members.
>>> (e.g.
>> layer->results) That
>>> could be made more high performance and hidden behind accessor
>>> methods in
>> mapscript. Users
>>> use getResult(int i) already.
>> I like that. And you enable this query cache by default for all data
>> providers that suffer from the double-pass query problem (postgis,
>> oracle, etc, but *NOT* shapefiles) and provide a PROCESSING directive
>> that can be used to turn off the query cache if someone wants to
>> disable
>> it to perform very large queries or for whatever reason, e.g.
>> PROCESSING "QUERY_RESULT_CACHE" "OFF"
>> Daniel
