AGG support
Steve Lime Steve.Lime at DNR.STATE.MN.US
Mon Mar 12 15:54:39 EDT 2007
Done...
>>> On 3/12/2007 at 10:27 AM, in message <45F52B0E.5157.008F.0 at dnr.state.mn.us>,
Steve Lime <Steve.Lime at DNR.STATE.MN.US> wrote:
> So, you just hacked configure.in to look in AGG_DIR/include/agg2 correct?
> (wonder if agg2 is somewhat standard) If so, no biggie I'll patch
> configure.in...
> Steve
>>>> On 3/12/2007 at 5:38 AM, in message <45F52D95.4060109 at sarvision.nl>, Vincent
> Schut <schut at SARVISION.NL> wrote:
>> Trying to get agg rendering to work, I found that mapserver only looks
>> for the agg includes in AGG_DIR (=/usr)/include. However, my gentoo
>> system has in it's devine wisdom decided to install these header files
>> in /usr/include/agg2. Alas, agg does not provide an agg-config utility
>> to find the header files location. Currently I have rigourously adapted
>> configure to look where these files are, but that's of course no long
>> term solution. As this might also occur with other linux distro's, maybe
>> even in slightly different locations, it might be something the
>> mapserver autoconf wizards want to look at :)
>> Cheers,
>> Vincent.
>> John Novak wrote:
>>> Tom,
>>> Please do provide input on your experiences with the new AGG code,
>>> Best,
>>> John Novak
>>> On 3/9/07, *Steve Lime* < Steve.Lime at dnr.state.mn.us
>>> <mailto:Steve.Lime at dnr.state.mn.us>> wrote:
>>>     Use at your own peril, but you can certainly play with it. John
>>>     Novak has done the bulk of the work to date
>>>     with new input coming from Assefa. It looks promising so many
>>>     thanks for the excellent work to date.
>>>     I don't believe there are extensions to the Windows Makefile but I
>>>     did commit configure support for *nix
>>>     yesterday. Works fine on my SuSE box. Just do a --with-agg=path to
>>>     agg when running configure and
>>>     it should work. You need agg version 2.4 at this point. Agg
>>>     doesn't have install scripts so I just left it
>>>     where I built it ( e.g. /usr/local/src/agg-2.4). Configure will
>>>     look for that type of setup or in the system libs.
>>>     To use simply plop a OUTPUTFORMAT in your mapfile like so:
>>>     OUTPUTFORMAT
>>>         NAME                myAggRgb
>>>         DRIVER      AGG/PNG
>>>         IMAGEMODE   RGB
>>>       END
>>>     RGB and RGBA are supported.
>>>     The AGG driver uses GD as the buffer manager, so basically AGG
>>>     renders to a GD image so we can use GD
>>>     file writing and any of the other GD writing code. That allows us
>>>     to concentrate on pieces of the rendering
>>>     while still creating complete images. At the moment I believe
>>>     polygons and lines are rendered using AGG
>>>     while markers and text fallback on their GD counterparts.
>>>     Steve
>>>     >>> On 3/9/2007 at 1:36 PM, in message
>>>     <2576812186CDD411BF1500508B6DCE9511B30C88 at ecnwri1.ontario.int.ec.gc.ca
>> <mailto:2576812186CDD411BF1500508B6DCE9511B30C88 at ecnwri1.ontario.int.ec.gc.ca>>
>>>     "Kralidis,Tom [Burlington]" < Tom.Kralidis at EC.GC.CA
>>>     <mailto:Tom.Kralidis at EC.GC.CA>> wrote:
>>>     > Just noticed mapagg.cpp in CVS HEAD.
>>>     > Is / can this be tried out?  Any build details?
>>>     > ..Tom
>>> John Novak
>>> Novacell Technologies and the Old Topo Depot
>>> http://www.novacell.com
>>> 877-old-topos
