request for comment: adding xslt processing to mapserver
Sean Gillies
sgillies at FRII.COM
Sun Mar 25 16:52:52 EDT 2007
Something like this:
# App config
Application
WFS
GetFeature
XSLT "/var/mapserver/xslt/envican.xsl"
End
End
End
# Cartographic Config
Map
End
When I talk about separation of concerns, that's what I mean. Separate
configuration blocks for cartography and web application.
Sean
Paul Spencer wrote:
> Sean,
> do you have any suggestions on what might be used for new keywords? At
> this point, I was planning to suggest using metadata to trigger it just
> to avoid adding new keywords :)
> Cheers
> Paul
> On 23-Mar-07, at 1:20 PM, Sean Gillies wrote:
>> Paul Spencer wrote:
>>> MapServer devs ...
>>> DMSG has a contract with Environment Canada/Tom Kralidis to
>>> implement some changes to the Sensor Observation Service.
>>> Part of this contract is to write a technical report on the
>>> feasibility of introducing the ability to transform XML coming out
>>> of MapServer's various OGC interfaces (specifically WMS
>>> GetFeatureInfo, WFS GetFeature and SOS GetObservation) using an XSLT
>>> directly in MapServer. I (with help from Assefa) have prepared a
>>> draft of this report structured more-or-less like an RFC.
>>> One of the requirements is to 'gauge the reaction of the TSC to this
>>> proposal', which is the purpose of this email. If the general
>>> feedback from you is positive, I believe Tom will then submit this
>>> as an RFC for approval and, if approved, will seek funding to
>>> implement the changes.
>>> Please give the attached proposal a read over and let me know:
>>> * would you be for or against this capability being introduced into
>>> mapserver?
>>> * if against, would any rewording or additional detail change your mind?
>>> * is there enough technical detail in the proposal?
>>> * is there anything obvious missing (I know I may have missed some
>>> files that would need to be modified)?
>>> * any other comments?
>>> I know this is last minute, but the report is due for mid next week
>>> so getting your feedback ASAP is highly desirable.
>>> Cheers
>>> Paul
>> I like it :) I'd like it even more if this kind of application
>> configuration was cleanly separated from the cartographic
>> configuration -- new keywords instead of adding new powers to existing
>> ones.
>> Cheers,
>> Sean
>> --Sean Gillies
>> http://zcologia.com/news
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
Sean Gillies
