request for comment: adding xslt processing to mapserver
Paul Spencer
pspencer at DMSOLUTIONS.CA
Sun Mar 25 17:10:47 EDT 2007
Cool, thanks Sean. I can see how this would be very appealing.
Cheers
Paul
On 25-Mar-07, at 4:52 PM, Sean Gillies wrote:
> Something like this:
> # App config
> Application
> WFS
> GetFeature
> XSLT "/var/mapserver/xslt/envican.xsl"
> End
> End
> End
> # Cartographic Config
> Map
> End
> When I talk about separation of concerns, that's what I mean.
> Separate configuration blocks for cartography and web application.
> Sean
> Paul Spencer wrote:
>> Sean,
>> do you have any suggestions on what might be used for new
>> keywords? At this point, I was planning to suggest using metadata
>> to trigger it just to avoid adding new keywords :)
>> Cheers
>> Paul
>> On 23-Mar-07, at 1:20 PM, Sean Gillies wrote:
>>> Paul Spencer wrote:
>>>> MapServer devs ...
>>>> DMSG has a contract with Environment Canada/Tom Kralidis to
>>>> implement some changes to the Sensor Observation Service.
>>>> Part of this contract is to write a technical report on the
>>>> feasibility of introducing the ability to transform XML coming
>>>> out of MapServer's various OGC interfaces (specifically WMS
>>>> GetFeatureInfo, WFS GetFeature and SOS GetObservation) using an
>>>> XSLT directly in MapServer. I (with help from Assefa) have
>>>> prepared a draft of this report structured more-or-less like an
>>>> RFC.
>>>> One of the requirements is to 'gauge the reaction of the TSC to
>>>> this proposal', which is the purpose of this email. If the
>>>> general feedback from you is positive, I believe Tom will then
>>>> submit this as an RFC for approval and, if approved, will seek
>>>> funding to implement the changes.
>>>> Please give the attached proposal a read over and let me know:
>>>> * would you be for or against this capability being introduced
>>>> into mapserver?
>>>> * if against, would any rewording or additional detail change
>>>> your mind?
>>>> * is there enough technical detail in the proposal?
>>>> * is there anything obvious missing (I know I may have missed
>>>> some files that would need to be modified)?
>>>> * any other comments?
>>>> I know this is last minute, but the report is due for mid next
>>>> week so getting your feedback ASAP is highly desirable.
>>>> Cheers
>>>> Paul
>>> I like it :) I'd like it even more if this kind of application
>>> configuration was cleanly separated from the cartographic
>>> configuration -- new keywords instead of adding new powers to
>>> existing ones.
>>> Cheers,
>>> Sean
>>> --Sean Gillies
>>> http://zcologia.com/news
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> Sean Gillies
